Shipping supplies for your items
« back to Sweating for Bucks Through Woodworking forum
Forum topic by JerrodMcCrary posted 10-03-2014 05:47 PM 1327 views 0 times favorited 17 replies Add to Favorites Watch
View JerrodMcCrary's profile
JerrodMcCrary
86 posts in 1628 days
10-03-2014 05:47 PM
Topic tags/keywords: shipping ship supplies damage boxes brown
I have been looking for shipping supplies and was wandering what other Lumber jocks members used for supplies for making sure your item was not damaged and where you bought them. Home depot seems pretty cheap on shipping boxes. Thanks for the reply, I forgot to mention items would be roughly 24-36” wide and 18” tall and 6” deep.
Thanks in advance,
Jerrod
17 replies so far
View mahdee's profile
mahdee
3888 posts in 1789 days
#1 posted 10-03-2014 05:52 PM
Depends on what you are shipping. A large furniture for example needs to be crated. If you checkout UPS website, they have some good information on how to properly package your items.
-- earthartandfoods.com
JerrodMcCrary
#2 posted 10-03-2014 05:56 PM
Thanks for the reply, I was just wandering if people used bubble wrap on wood and it that ever caused a problem or do I need to use tissue paper then bubble wrap and info like that. Ill have to go check out UPS, I know they use a lot of packaging peanuts.
mahdee
#3 posted 10-03-2014 05:56 PM
Sorry, it was FedEx
Mahdee
mahdee
#4 posted 10-03-2014 06:01 PM
Again depends on what you are shipping. A cutting board may be wrapped with bubble wrap and some waded up news paper for cushion and stating on the postage fragile. A fragile piece like this may require an outer wooden box.
View jmartel's profile
jmartel
7950 posts in 2172 days
#5 posted 10-03-2014 06:35 PM
I haven’t needed to ship large or fragile items, but since I order a lot from online anyway, I’ve just kept a stash of packing peanuts, bubble wrap, the larger air bubbles, cardboard boxes, etc.
View Rayne's profile
Rayne
910 posts in 1561 days
#6 posted 10-03-2014 11:51 PM
Check CL for FREE boxes and packing materials. I just got rid of mine with several replies within a couple of days, so it may be worth a look.
JerrodMcCrary
#7 posted 10-04-2014 07:05 PM
Thanks I haven’t thought about the CL route, but I found a corrugated rap roll that pretty much lets you wrap your piece in it. I thought I could attach bubble wrap to it then that would be a good way to ship varying sizes of items and you don’t really have to deal with having numerous sizes of boxes to deal with. Thanks for the replies everyone.
View camps764's profile
camps764
867 posts in 2381 days
#8 posted 10-04-2014 07:18 PM
I order 4×8 sheets of double wall corrugated cardboard from Staples. It’s cheap. Then I build my own boxes. You can also go to U-haul and they usually have piles of free boxes you can snap and cut up.
-- Steve
View johnstoneb's profile
johnstoneb
2932 posts in 2194 days
#9 posted 10-04-2014 09:20 PM
Shipping toys I cut a piece of 1/4” plywood the size of the box bottom drill holes in it a nd strap the toy to the plywood so it can’t move then wadded newspaper, bubble wrap, peanuts whatever around and on top of.
-- Bruce, Boise, ID
View JAAune's profile
JAAune
1801 posts in 2338 days
#10 posted 10-05-2014 01:07 AM
We buy a lot of veneer which means we get lots of kraft paper and that is what we use to wrap/cushion smaller items. Like Camps, we will make custom boxes as needed only our cardboard comes from the plywood supplier. We usually get a couple free sheets with each wood order.
For special items that need specific packing materials, Uline is a good place to buy supplies. For the most part though, we just recycle packing materials and boxes that our suppliers send us (Certainly Wood and McMaster Carr are two of them).
For small but heavy items, it’s hard to beat USPS flat rate shipping. Free boxes and a flat price no matter how heavy the item might be.
View GerryB's profile
GerryB
69 posts in 2604 days
#11 posted 10-05-2014 03:41 AM
Among other things, I paint. When I have a canvas to ship, I make a box of “1 by” cover one side with door skin which is usually pretty cheap at the discount lumber place. Sometimes it is low quality, but it works. I wrap the painting with bubble wrap, maybe wedge some cardboard to keep it from moving, & close the box with stapled cardboard. I always make sure to put the “front” side of the painting to the door skin side to protect it.
-- The pursuit of excellence is gratifying and healthy. The pursuit of perfection is frustrating, neurotic, and a terrible waste of time. Edwin Bliss
View MT_Stringer's profile
MT_Stringer
3172 posts in 3253 days
#12 posted 10-05-2014 04:55 AM
Uline has anything you could possibly need.
View Yonak's profile
Yonak
986 posts in 1543 days
#13 posted 10-05-2014 05:22 AM
A couple of thoughts :
1. Rolled corrugated, while less expensive, is two dimensional in use. You can only wrap around a piece in two axes per length of material (it doesn’t really twist), which makes it more cumbersome to use. Bubble wrap you can wrap on all sides.
2. In Atlanta we have an overstocks box seller where we get boxes pretty inexpensively, when specific sizes are not necessary, compared to ordering from a corrugated supplier. Maybe there’s such a thing in your area.
It really pretty much depends on your volume and what kinds and weights of things you’re shipping.
View Jim Finn's profile
Jim Finn
2657 posts in 2943 days
#14 posted 10-05-2014 12:21 PM
I also buy my boxes at Uline
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Puzzleman's profile
Puzzleman
417 posts in 2966 days
#15 posted 10-06-2014 12:07 PM
With buying from Uline, you can get boxes that fit your needs exactly or pretty darn close. This will save time in the packaging area and looks more professional. Your packaging should reflect the expense of your product. You do not want to ship a $100 item in a reused box with newspaper. It reflects that you don’t care how your product looks when it gets there. Using new packaging reflects that you care about your product and want it to be in the best shape possible when it arrives.
The first thing the customer will see of your product is the package, make it look good. Yes, it does cost more but calculate that cost into your product just like you do with your wood and other items. when you receive an order, don’t you feel better when the vendor uses a new box instead of reusing someone’s box with their tape, logo and shipping label still on it.
-- Jim Beachler, Chief Puzzler, http://www.hollowwoodworks.com
