Best Dado Blade for Saw Stop?
Forum topic by cmillsrun posted 10-03-2014 02:44 PM 10910 views 0 times favorited 22 replies Add to Favorites Watch
View cmillsrun's profile
cmillsrun
34 posts in 1461 days
10-03-2014 02:44 PM
Topic tags/keywords: tablesaw saw stop dado
Hi all,
I recently purchased a Saw Stop Professional 3hp saw (first big table saw- yay!). I was in the process of choosing which dado stack I wanted to purchase and had come the conclusion that I wanted the Dadonator.
My issue is that when I purchased the new dado saw stop brake cartridge there were explicit instructions not to use dado stacks that had full blades for the chippers as this would add too much weight and could bend the arbor if the brake is activated. Now, of course I don’t ever plan to activate the brake but at the same token a bent arbor is way worse to fix then a blade/cartridge.
Does anyone have experience with dado’s on the Saw Stop? Would something like the Forrest King Dado be a better choice since it’s chippers aren’t as bulky? Any other dado blades that you’d recommend or am I just irrationally worrying?
Thanks!!
-- -Chris
22 replies so far
View ChrisK's profile
ChrisK
1907 posts in 2984 days
#1 posted 10-03-2014 03:55 PM
This is I found on the saw stop web site:
Do not use dado sets with solid-plate interior chippers or blades with molding heads, as neither brake cartridge is designed to stop those blade types.
The Dadonator seems to fit that bill. Call Saw Stop and get right fro their mouths.
-- Chris K
View knotscott's profile
knotscott
7871 posts in 3279 days
#2 posted 10-03-2014 10:17 PM
I’d definitely call Saw Stop and ask if the Dadonator is compatible, because in my view it doesn’t really a have full plate chippers….it’s more like 75%. A set like the Oshlun or Systimatic are closer to full plate. I’m sure it boils down to mass.
vs:
knotscott
#3 posted 10-03-2014 11:30 PM
If the issue really does come down to mass, I wonder if you could use any set as long as you didn’t load it to quite full width? Less width, less mass.
cmillsrun
#4 posted 11-12-2014 09:02 PM
I ended up going with the Forrest Dado King and love it! Thanks for the help and opinions!
-- -Chris
View Woodbum's profile
Woodbum
802 posts in 2968 days
#5 posted 11-12-2014 09:21 PM
Chris: I too have an 8” Dado king, but do not use it on a sawstop. Very high quality cuts. I am very happy with it too.
-- "Now I'm just another old guy wearing funny clothes"
View PatrickT's profile
PatrickT
5 posts in 649 days
#6 posted 05-10-2016 09:19 PM
Ran across this thread when doing some research on dado blades for my PCS 31320 and thought I’d add some info -
The salesman at Acme tools showed me an e-mail he received from their Sawstop. They cautioned against blades that have shoulders (Like these) because the blade takes longer to stop.
Specifically, the rep recommended against ‘all current’ Freud dado blades and the Oldham 12T dado set. The Forrest DK08244 and DeWalt DW7670 8” stacks were listed as being OK.
Interestingly, this is not on their web site, although they do reference shoulders in the manual.
I was planning on getting a Freud SD308 but now am torn. I can’t really justify $300 for a dado stack and I really liked the Freud set I had on my old saw, but since the entire reason I purchased the Saswtop was for increased safety, it doesn’t make sense to defeat that with an incompatible blade. I’ll probably end up getting the DeWalt stack – people seem to be happy with it and it’s got a nice case! :)
knotscott
#7 posted 05-11-2016 12:24 AM
The DeWalt/Delta 7670 set is a very good set and a great value in the $120 range. It has a similar design as the Forrest, and should work well with a Saw Stop saw. It doesn’t have full plate chippers, and doesn’t have the anti-kickback shoulders.
View TarHeelz's profile
TarHeelz
58 posts in 1984 days
#8 posted 05-11-2016 12:45 AM
I have a Forrest that I like with my SawStop. Regular chipper interior rather than plates. (I originally bought the Oshlun before reading the instructions. Fortunately a fellow NC Woodworking member swapped with me.)
-- Tar Heelz, Durham, NC USA
View zake1000's profile
zake1000
3 posts in 1807 days
#9 posted 05-18-2016 12:30 AM
Hi, I just purchased a SawStop and I’m in the market for an approved dado set, so I thought I’d add a comment on this. I’ve been communicating with SawStop about dado sets and the following is what I got in an email:
Any 8” standard-tooth steel stacked dado set (max width: 13/16”) with steel or carbide teeth can be used. For best results, purchase a zero-clearance insert for your dado set.
Do not use dado sets with solid-plate interior chippers, blades with molding heads, or “wobble” dado sets as the brake cartridge is not designed to stop those blade types. Also do not use blades with tooth “shoulders” (often called depth-limiting or anti-kickback shoulders), as these blades will take longer to stop in the event of an accident.
here are examples of popular Dado Stack SKUs that meet the qualifications and can be used on all SawStop saws:
·         Forrest Dado King DK0824XXX (5/8” arbor)
·         DeWalt DW7670
·         Tenryu GMD-20340
·         King Canada KSC-8000
·         Amana 658040
The dado sets above are the only ones that so far meet SawStop criteria to be used with their dado brake. The question is not what dado sets fit the SawStop, because a dado set that is 8” will fit it, but rather as someone else stated earlier, is an issue of the brake being able to stop the blade in the least amount of time.
Hope that helps
PatrickT
5 posts in 649 days
#10 posted 05-18-2016 12:47 AM
Thanks for adding to the list, Zake.
I purchased the DeWalt dado set and am very impressed, especially for the price. Very Clean, flat dados with no chip out. Of the dado sets that meet the Sawstop criteria, I think the DeWalt is the best value. I’ve heard nothing but good things about the Forrest Dado King, but I can’t see it doing that much better than the DeWalt.
View clin's profile
clin
792 posts in 899 days
#11 posted 05-18-2016 03:19 AM
FYI, Just decided to pop for the Dewalt DW7670 set (I have SawStop PCS). Just bought it off Amazon. And was confused by a $20 off discount at the end. It was listed at about $115, and was $95 at checkout.
Went back and looked and Amazon has a $20 off of $100 for select Dewalt items sold by Amazon from now through June 19th. I noticed they listed some other popular Dewault tools like the DWP611 router.
Anyway, a pleasant surprise.
-- Clin
View ptbIII's profile
ptbIII
2 posts in 451 days
#12 posted 11-25-2016 05:11 AM
Sharing an on topic experience – I own a PCS and started using a Freud SD508 a few projects ago. Every thing has been fine, both using a sled and buried in a sacrificial fence. Today, doing a test cut on the sled for some cabinet wall dados, the brake tripped. THUNK!
I am not positive what happened. The SD508 is actually 8-1/8” in diameter, and I have to crank the brake distance adjustment to the stop to get close to the requisite clearance. During setup I did not measure the gap, I just adjusted to the stop and made sure the stack would rotate freely by hand a couple of full turns. I set the blade height for the cut, plugged in, turned on, and started the blade. I made the test cut and was bringing the sled back to the front. About half way through the test piece on the return the brake activated. My best guess is that blade and brake made contact triggering the brake. I ruled out the test piece, it is bone dry with no evidence of conductive material and the brake didn’t trip on the first pass. I am wondering if I didn’t really adjust all the way to the stop during the setup?
Anyway, there goes the better portion of three bills. I am going to replace the stack with one that is closer to 8” diameter and doesn’t have the anti-kickback shoulders. I am hoping the DW7670 meets the diameter spec as it sounds like the best value.
On the bright side I think I now have a really good start on making a shop clock
-- Paul
View RogerM's profile
RogerM
790 posts in 2302 days
#13 posted 11-25-2016 02:01 PM
The Dadonator dado set performs well and is hard to beat.
-- Roger M, Aiken, SC
knotscott
#14 posted 11-25-2016 02:06 PM
- RogerM
Are the sets that have anti-kickback shoulders an obstacle for Saw Stop?
View Sunstealer73's profile
Sunstealer73
140 posts in 1995 days
#15 posted 11-25-2016 03:20 PM
I bought the Craftsman one that is identical to the Dewalt/Delta 7670 for my PCS. It cuts very clean and flat dadoes. I used points to buy it, so it was a great value, for me at least.
