What is your favorite router and lift
Forum topic by GT350 posted 10-03-2014 12:44 PM 2005 views 0 times favorited 46 replies Add to Favorites Watch
View GT350's profile
GT350
362 posts in 1889 days
10-03-2014 12:44 PM
I am getting ready to build a router table and I am lookng at routers and lifts. Which router and router lift do you like and why? Also, is there a reason besides price that I would want to go with a smaller router?
Thanks
Mike
46 replies so far
4883 posts in 2401 days
#1 posted 10-03-2014 01:29 PM
I have a Milwaukee 5625 in a Woodpecker’s PRL ( the first one). The Woodpecker stuff is extremely good, and thier CS is as good as any you’ll find. But you pay for it (through the nose) and if i was doing it over I’m not sure I’d buy a lift. The 5625 has table features built in, and I might be inclined to try it that way for awhile and see how it goes.
View Redoak49's profile
Redoak49
3077 posts in 1896 days
#2 posted 10-03-2014 01:36 PM
I have the Woodpecker UniLift and a PC 7518. I have had both for quite a few years and never been disappointed. Woodpecker makes some very sturdy and very good lifts. The PC 7518 has been one of the routers used in many router tables.
View bondogaposis's profile
bondogaposis
4611 posts in 2259 days
#3 posted 10-03-2014 01:55 PM
I have the Bosch 1617 EVS in conjunction w/ a Incra Masterlift II. I really love it. Prior to getting the lift I had a Freud 2000 router in the table w/o a lift. I wondered, why did I wait so long to get a lift? It so much easier an convenient.
-- Bondo Gaposis
View EPJartisan's profile
EPJartisan
1118 posts in 3033 days
#4 posted 10-03-2014 02:29 PM
I decided to go whole hog a few years ago and purchased a Bench Dog cast iron table (with the extension wing) and Pro-lift with a variable speed 2hp Porter cable router… best thing is the lift carries the router through the top surface for changing bits…which allows fine adjustment as well, The fence is nice too. The the cast iron top is solid and heavy and feels safer for control. Love it and never regretted the investment. It is the third most used stationary power tool in my shop. (1st is bandsaw, 2nd is table saw).
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
View jacquesr's profile
jacquesr
339 posts in 1331 days
#5 posted 10-03-2014 03:32 PM
I did a lot of research to answer the same question.
The answer is…. Mastr-II form Jessem, but the Incra version with magnalock.
I also asked Neal at Incra which one was the best/most accurate between their version of the woodpeck and their version of the Jesem… his answer was “we sell 4 jessem for 1 Woodpeck….
i am ordering the Jessem from Incra.
View Matt Przybylski's profile
Matt Przybylski
539 posts in 2285 days
#6 posted 10-03-2014 03:59 PM
I too have the Incra Mast-R-Lift II and love it. It’s a fantastic lift and allows for very precise adjustment. The Magnalock rings are great and the new Clean Sweep Magnalock rings even better for under the table DC. I have a Porter Cable 7518 in mine and it works fantastic.
-- Matt, Arizona, http://www.reintroducing.com
View timbertailor's profile
timbertailor
1594 posts in 1332 days
#7 posted 10-03-2014 04:31 PM
I have a Milwaukee 5625 in a Woodpecker s PRL ( the first one). The Woodpecker stuff is extremely good, and thier CS is as good as any you ll find. But you pay for it (through the nose) and if i was doing it over I m not sure I d buy a lift. The 5625 has table features built in, and I might be inclined to try it that way for awhile and see how it goes.
- Fred Hargis
Me too. I have mine matched with an Incra Wonder Fence System. Also doubles as an assembly table. See my projects for ideas.
timbertailor
#8 posted 10-03-2014 04:33 PM
- jacquesr
His response really did not answer your question. By that logic, McDonalds makes the best hamburgers.
View Kajunaviator's profile
Kajunaviator
3 posts in 1524 days
#9 posted 10-04-2014 01:22 AM
I built the Norm Abrams router table and put a Jessem Route-R-Lift in it with a Craftsman 14 Amp router and it is very impressive.
View Woodmaster1's profile
Woodmaster1
894 posts in 2495 days
#10 posted 10-04-2014 02:45 AM
I have the rockler lift . It vibrates down so after setting it I use a wedge to keep the setting. I purchased a Triton router, so will see how it’s built in lift works. I still need to make the cabinet but the table is done.
View retfr8flyr's profile
retfr8flyr
381 posts in 1576 days
#11 posted 10-04-2014 03:49 AM
I too have the Incra Mast-R-Lift II and love it. It s a fantastic lift and allows for very precise adjustment. The Magnalock rings are great and the new Clean Sweep Magnalock rings even better for under the table DC. I have a Porter Cable 7518 in mine and it works fantastic.
- Matt Przybylski
I have basically the same setup, mounted in my table saw and I can’t say enough good things about it. The Incra Clean Sweep system with the Magnalock inserts is fantastic for DC.
Woodmaster, I tried the Triton in my table and got tired of having to go under the table to lock everything after every adjustment. It will move during the cut, if not locked.
-- Earl
View JAAune's profile
JAAune
1780 posts in 2224 days
#12 posted 10-04-2014 04:02 AM
We use the first edition of the Woodpecker lift and it’s provided flawless service for at least 4 years now. Other than an occasional squirt of lubricant on the moving parts the only maintenance has been to remove the occasional burr from the aluminum plate when someone nicks it with a router bit or wrench.
View B4B's profile
B4B
158 posts in 1266 days
#13 posted 10-04-2014 05:28 AM
Has anyone tried one of these shop-made lift from Matthias Wandel? http://woodgears.ca/router_lift/index.html or http://woodgears.ca/router_lift/version1.html
I have not, but seemed to be an appropriate time/place to ask. His designs seem to have high praises from what I’ve seen here at LJ.
-- There's two routers in my vocab, one that moves data and one that removes wood, the latter being more relevant on this forum.
View DrTebi's profile
DrTebi
265 posts in 3174 days
#14 posted 10-04-2014 07:23 AM
I was looking at various router lift options about 1 1/2 years ago or so, and eventually bought the Jessem Mast-R-Lift Excel II: http://www.jessem.com/MAST-R-LIFT_EXCEL_II.html
One of my biggest complaints about my old router table was the router insert plate. It just never wanted to stay flat. The Mast-R-Lift Excel does only have insert rings, no insert plate at all, and that was the most compelling feature that made me buy it.
After having used it for a while, I only have two minor complaints:
1) I wish they had used a few more stainless steel or brass parts—I am not getting a lot of moisture in my basement shop, but I do get some, and a few screws and the crank-shaft now show some minor rust. This can certainly be prevented with some WD40 or similar, however these parts seem to be more “attracted” to rust than most of my other tools in the basement.
2) The dust port on the bottom is a nice idea, but certainly no replacement for an enclosed under-table solution. It will still let quite a bit of saw dust fall down.
Other than that, really a great lift, good quality top, and great miter slot too.
DrTebi
#15 posted 10-04-2014 07:44 AM
Interesting, I just checked out the differences between the Mast-R lift from Incra and the Mast-R lift Excel from Jessem.
I think the magnetic insert rings are great, but I would definitely prefer the side-crank of the Excel version. I have several times cut mortises on my router table, and I usually set up a few stops and featherboards to keep everything well aligned. But since I don’t rout the mortises in one pass, I need to lift the bit several times, while my setup stays the same. This is where I would not like the crank from over the top of the table… since I wouldn’t be able to get to it easily. With the crank on the side of the Mast-R-Lift Excell however, it’s really simple, the crank is never in the way.
Just something to think about…
showing 1 through 15 of 46 replies
