Removing glue squeeze out from finished wood
Forum topic by mustang958 posted 10-02-2014 11:40 PM 923 views 0 times favorited 1 reply Add to Favorites Watch
View mustang958's profile
61 posts in 3081 days
10-02-2014 11:40 PM
Topic tags/keywords: glue squeeze out dried glue glue finished wood
Creating a project with some salvaged oak flooring from a home that was flooded by hurricane Sandy. Most of the wood being used has been planed to remove the finish. Some of the wood will retain the original finish and has been glued up to form some panels for the project. Was able to remove the majority of the glue squeeze out from this but some remains. What is the best way to remove the remaining dried glue? I don’t want to and/or can’t sand at all really or scrape too much because the intention is to retain the finish. Appreciate any suggestions.
1 reply so far
View mahdee's profile
3852 posts in 1701 days
#1 posted 10-03-2014 12:02 AM
Use a sharp chisel with the angle on the surface. Then use the chisel like a scraper to remove the rest.
