Removing point from live center
« back to Woodturning forum
Forum topic by kmetzger posted 10-02-2014 04:57 PM 1204 views 0 times favorited 4 replies Add to Favorites Watch
View kmetzger's profile
kmetzger
157 posts in 1786 days
10-02-2014 04:57 PM
I have a copy of the Grizzly G 0462 marketed in Mexico and want to remove the point from the tailstock live center to hold a 1/2” dowel. On the Jet lathe I used before, all I had to do was tap the point out with a rod through the hollow rear-end of the Morse taper. On this live center there’s a set screw. I loosened the set screw and tried to tap out the point from behind but it wouldn’t budge. Does anyone know if the point will come out if I pound on it hard enough?
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
View TheDane's profile
TheDane
5405 posts in 3632 days
#1 posted 10-02-2014 06:24 PM
Kim—Just a WAG on my part (I don’t have this lathe), but I would say if there is a set screw, it must have been designed to come out.
I had a similar question recently about the spur in my Delta live center. I removed the set screw, shot some WD40 into it, than set it point down on a wood block and rapped the back side with a hammer and pin punch (I wouldn’t use a regular punch as it could mushroom the blunt end of the spur). It took a couple of raps to get it free, but now I can remove/replace it as needed.
HTH
View JADobson's profile
JADobson
1015 posts in 2080 days
#2 posted 10-02-2014 06:48 PM
I don’t have the exact same lathe but my live centre had a set screw. It popped out with a little coercion from a mallet and knock out bar.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany
View Wildwood's profile
Wildwood
2300 posts in 2103 days
#3 posted 10-02-2014 07:05 PM
I could be wrong but do not think you can remove the live center point looking at this manual.
http://cdn0.grizzly.com/manuals/g0462_m.pdf
Nova sells an inexpensive live center with different removable tips, sells for around $70 here unless on sale.
-- Bill
kmetzger
#4 posted 10-02-2014 07:35 PM
Thanks, everyone. I followed Gerry’s advice and a little WD-40 did the trick.
