De-bugging aged wood
Forum topic by Luch posted 10-01-2014 08:20 PM 1095 views 0 times favorited 4 replies Add to Favorites Watch
View Luch's profile
Luch
3 posts in 1332 days
10-01-2014 08:20 PM
Hello – I’m new to this site and I need some help. Has anyone had success using an enclosed cargo trailer as a make-shift kiln? I’m considering running a few electric space heaters. Will this get me the 130+ degree temp I need to kill powder post beetles? I have an 8×8 barn beam that I plan to use as a mantle. There are indications (pin holes) that beetles were present but I don’t know if they still are.
View mahdee's profile
mahdee
3883 posts in 1766 days
#1 posted 10-01-2014 08:24 PM
Hi,
Make your mantel first, then heat it up. The cargo trailer should create enough heat by itself if left in the sun. 130-140 needs to penetrate. Put a candy temperature gauge in there and check it out. I have used my truck left in the sun and windows barely cracked open.
-- earthartandfoods.com
View Luch's profile
Luch
#2 posted 10-01-2014 08:28 PM
Thanks. Curious, what’s the benefit of cuttings he mantle first?
View catalina's profile
catalina
9 posts in 2346 days
#3 posted 10-01-2014 11:13 PM
smaller pieces reach temp faster.
View Nomad62's profile
Nomad62
726 posts in 2956 days
#4 posted 10-02-2014 05:39 PM
Most household electrical appliances are not rated to run in such a hot environment; an industrial model could do it. A beam that large will take a while to cook as the center needs to get that hot, probably 12-14 hours would be a minimum if you could get the room up to 150 or so. Perhaps a small kerosene salamander could work with care as well.
