Damaged table saw blade after cutting into screw
Forum topic by woodoogolem posted 10-01-2014 05:32 PM 1444 views 0 times favorited 11 replies Add to Favorites Watch
View woodoogolem's profile
woodoogolem
56 posts in 1422 days
10-01-2014 05:32 PM
Topic tags/keywords: question tablesaw damage blade
I recently made a cut into a metal screw which damaged the blade severely. Afterwards it made a strange noise while cutting, a bit of a buzzing or growling sound. The bottom edges are really rough now, no clean cut at all.
Some of the teeth had small splinters on the outside. So I tried resharpening all the teeth and removing or filing the splinters with a diamond stone below the outer diameter of the teeth, Since this did not help much, I put a grinding stone to all 3 outer blade sides while rotating the blade backwards with my hand.
I can not feel any rough or protruding parts on any of the teeth but there is still this growling sound and the edges are still rough.
Any ideas how to get the blade back into good shape?
11 replies so far
View JAAune's profile
JAAune
1797 posts in 2312 days
#1 posted 10-01-2014 05:36 PM
Send it to a professional resharpening service. They’ll inspect it and tell you if the teeth need replacing or resharpening or if the whole thing is damaged beyond repair. If the blade is an inexpensive hardware store purchase then get a new one as the saw company will likely charge at least $25 to do anything plus the cost of shipping.
We use RKO Saw for our sharpening service.
View jmartel's profile
jmartel
7882 posts in 2145 days
#2 posted 10-01-2014 05:40 PM
Replace the blade.
View bigblockyeti's profile
bigblockyeti
5112 posts in 1716 days
#3 posted 10-01-2014 05:57 PM
Definitely send it out, someone who sharpens and repairs blades can determine if the blade can be salvaged (& whether or not it would be worth it to). Using a blade that’s been damaged could be very dangerous if the brazing holding one or more of the teeth onto the plate has been compromised. The teeth on most table saws are going right around 120mph, and while they’re not very big, they are very dense and could case severe damage and injury if they came off at the right time.
4983 posts in 2488 days
#4 posted 10-01-2014 07:12 PM
To emphasize what’s been said already: either a pro, or replace. The first may suggest the second, but usually if it’s an expensive blade they can fix up fairly easily.
View Underdog's profile
Underdog
1095 posts in 2031 days
#5 posted 10-01-2014 07:18 PM
Is that a High Speed Steel blade, or carbide tipped blade?
Even if you succeeded in removing the chipped places on the blade with your method, you will not have the correct clearance angles after that procedure.
Again, replace or professional resharpening.
Resharp costs around here are typically between $.35-.45 per tooth. If it’s a cheap blade with large number of teeth it’s definitely better to replace it.
-- "woodworker with an asterisk"
woodoogolem
#6 posted 10-01-2014 07:56 PM
thanks everybody for their words of caution :-)
I have been thinking myself about the possibility of teeth partially coming loose. I just had some slight hope for some trick to find the maybe one offending tooth on a rather new (but not too expensive) blade.
I will go the safe route and already have ordered a new one as I don’t think professional repair will safe me a lot.
View exelectrician's profile
exelectrician
2327 posts in 2422 days
#7 posted 10-01-2014 08:12 PM
You totally un balanced the blade with your grinder, That is why you have the growling noise.
Replace the blade, it is toast.
-- Love thy neighbour as thyself
View knotscott's profile
knotscott
8008 posts in 3371 days
#8 posted 10-01-2014 08:12 PM
What blade is it?
exelectrician
#9 posted 10-01-2014 08:14 PM
View Todd's profile
Todd
398 posts in 1671 days
#10 posted 10-02-2014 07:27 PM
I would be afraid of flying carbide. I would be inclined to replace it, or at least send it to a professional sharpener.
-- Todd, Huntsville, AL
View mudflap4869's profile
mudflap4869
1731 posts in 1454 days
#11 posted 10-02-2014 07:39 PM
Bottom line. What is your safety worth. Several thousand rpm = carbide bullet.
-- Still trying to master kindling making
