help with angles
« back to Joinery forum
Forum topic by VTdscglfr posted 09-30-2014 08:31 PM 1093 views 0 times favorited 10 replies Add to Favorites Watch
View VTdscglfr's profile
VTdscglfr
23 posts in 1779 days
09-30-2014 08:31 PM
So I’m making a mobile for my son and I can’t for the life of me figure out what angle to set my table saw in order to join these six parts. I’m gonna join the mites then drill and insert dowels in order to strengthen the joint. Would someone help please. Thank you. I will be doing it with my tenon jig so they will be flat side down.
10 replies so far
View mahdee's profile
mahdee
3843 posts in 1671 days
#1 posted 09-30-2014 08:37 PM
Will there be a hex or a round piece they connect to? What is a mobile?
-- earthartandfoods.com
VTdscglfr
#2 posted 09-30-2014 08:51 PM
No they will be mites that connect and I will be shaping them after joined
View jtmek's profile
jtmek
65 posts in 2740 days
#3 posted 09-30-2014 08:59 PM
You have six parts to cut, so 360 divided by 6 equals 60 degrees, two cuts per part, divide by two so 30 degrees.
Just Remeber a circle is 360 degrees , so divide by the number of cuts. In your case 360 divided by 12 equals 30 degrees
Hope this helps
Jtmek
-- a good woodworker can fix his mistakes, agreat w/w can fix them before anybody see's them
View Earlextech's profile
Earlextech
1160 posts in 2594 days
#4 posted 09-30-2014 09:01 PM
360 degrees/6 pieces = 60 degrees.
Each joint has two pieces so divide 60/2= 30 degrees each side of a joint.
Set the saw at 30 degrees.
I would use my chop saw for this cut. Mark a center line and cut very precisely to it.
View papadan's profile
papadan
3584 posts in 3272 days
#5 posted 09-30-2014 09:02 PM
360 /6=60/2=30 degrees.
VTdscglfr
#6 posted 09-30-2014 09:04 PM
That is my chop saw may be easier to it on the table saw
View Dallas's profile
Dallas
3599 posts in 2391 days
#7 posted 09-30-2014 09:14 PM
That old miter box of yours is probably more accurate than 90% of the table saws around today.
Now get the back saw for it.
VTdscglfr
#8 posted 09-30-2014 09:16 PM
You mean that guy…
View waho6o9's profile
waho6o9
8099 posts in 2481 days
#9 posted 09-30-2014 09:53 PM
+1 for Dallas
VTdscglfr
#10 posted 10-01-2014 11:38 PM
So I cut this little angle guide based off my incra mitre guage.
But which angle do I set my blade off of.
I plan on using this style jig and adding some hold downs.
