Will this matter when it comes to building codes for kitchens, in NY state (if it matters?)
I am considering remodeling the kitchen and want to move an outlet at around 65" high behind the stove, currently with no cabinets on that wall, into a new cabinet above the [new] over-the-range microwave. I think usually these cabinets are wasted, sometimes with ducting for an exhaust fan. I'd like to make a plate rack cabinet there, and have the microwave plug in (instead of hard wiring), maybe in an outlet inside a partition at the end. I can also open the little door and plug in another appliance that may sit on the stove when the stovetop's not in use, like the deep fryer, hand mixer, outboard motor mixer, etc.
This would involve moving an existing outlet that the gas range plugs into about 18", and so an OTR microwave can plug into, plus other small appliances, room allowing.
I have a receptacle in the back of the cabinet over the microwave/range vent and it was done when the house was built. This to me is far preferable than having something hardwired with just a wire poking through the wall, much cleaner.
Built in dishwashers are usually plugged in under the sink cabinet. And I have also seen garbage disposals so the outlet and switch are in the cabinet also
Always check with your local codes because they are the devil (mostly). It's probably okay but they may have rules regarding exactly how it's placed, whether the cabinet is open or has a door, the voltage, etc., etc.
If it's mounted flush to the wall your fine, if you want the outlet and cover to sit flush with the back of the cabinet you'd have to use a gang box extender.
Thanks everybody! Then I will mount the box flush to the wall and make the back of the cabinet open in that area and make a door for the front or a tambour.
Anybody know any code about minimum distance the surrounding wall cabs must be from the stove? I know most wall cabs go 18" above countertop but I do some canning (google Annie's Salsa) and the pressure canner is pretty tall so was thinking 24" from stove to bottom of OTR microwave, but can the wall cabs surrounding the microwave hang lower?
Any outlet that serves counter top space in a kitchen needs to be GFCI protected per the 2011 NEC. Since you plan to leave this outlet accessible to plug in other counter top appliances if needed may make that outlet subject to the GFCI requirement.
Would this be considered as such? It will be ~33" above the countertop… I'm all for safety but do they have a 4-outlet GFCI receptacle? Or can I stack 1 above another on the wall? And is the code for countertop area or entire kitchen? I would probably need one behind the stove instead of where it is now. Would a breaker be cheaper or would I do one GFCI and connect the restof the recptacles downline?
They are OK here. Our dishwasher and garbage disposal both are plugged into a GFI outlet inside the undersink cabinet in the kitchen.
Also seen outlets away from water in a cabinet to handle some of the messes of all the charging stations for cordless mixers, and cellphones, and undercabinet TV's
Here and in Indiana, circa 1998, a receptacle in the kitchen had to be GFCI and had to be 18" away from any water source, (even lines in the wall including waste pipes or stacks).
I forgot to mention, you are allowed to use a GFCI breaker to service your receptacles up to a certain number.
- WhyMe
Would this be considered as such? It will be ~33" above the countertop… I m all for safety but do they have a 4-outlet GFCI receptacle? Or can I stack 1 above another on the wall? And is the code for countertop area or entire kitchen? I would probably need one behind the stove instead of where it is now. Would a breaker be cheaper or would I do one GFCI and connect the restof the recptacles downline?
All I can say is what NEC states. It says outlets installed to serve counter top surfaces in kitchens shall be GFCI protected, there is no distance set in the code. The cheapest way is to have the outlets protected by an upstream GFCI outlet. You can also use a double gang box with 1 GFCI outlet protecting the second outlet.
2000W /125V = equal about 16a, significantly more than a 15a breaker should handle.
Still not even close to a 20A circuit breaker.
Remember, your breakers are subject to heat failure. If they are subject to 90-110°F, whether actual or from otherheat from the breaker box, they may fail.
Circuit breakers are only rated for 80% load. If it exceeds that you'll find all bets off.
2000 watt??? Is that typical? I thought mine was 1000 or 1100w. I'll have to dig out the manual-the microwave is brand new, sitting in its box since around 2007, on top of the new fridge. I'm using the fridge & stove already, couldn't wait…
Circuit breakers are only rated for 80% load. If it exceeds that you ll find all bets off.
It's not that breakers are rated for 80%, it's that the NEC allows for the continuous circuit load to be no more than 80% of breaker capacity. So 16A is the max allowed continuous load on a 20A circuit.
OK, the microwave box says 950W and the Install sheet says 120V, 1600W. It is a convection microwave (can heat up to 450 degrees F.) It can be ducted or recycling. The old 1940's stove had a duct up & a 90* turn to the right-the chimney is maybe a foot to the right of the stove. The new stove doesn't vent anywhere. My hope is to find a way to have a 110V receptacle, a plate rack w/maybe 6-10 dishes, and maybe even a functioning duct…
The code states that any receptacle serving a kitchen counter must be GFCI protected. This does not state any distance. That is old code. All islands must have a receptacle. The receptacle behind the range and the receptacle in the cabinet for the microwave does not serve the kitchen counter. Microwaves usually come with a manual that states they recommend you put them on their own circuit. If you vent them outside the room, they MUST go outside the home and have an approved hood or vent closure on the end. This closure must have a backdraft preventer in it. Vent hoods cannot exhaust into the attic. There are further codes for the pipe on the hood. I see electric receptacles in cabinets every day. They are good but you can't build them and decide to throw the door open and plug in your mixer 6 or 7 feet above the counter. Cabinets are typically 16 inches above the counter surface.
The outlet for our microwave was above it in the small cabinet. If I understand it, it must be on a dedicated 20 amp circuit. The outlet is in a conduit box with an extender and the plastic duplex cover on it.
If I was adding the outlet for the microwave, I'd put in a dedicated 20A circuit. And since you are placing it to be available for counter/stove top use I'd make it GFCI.
Plugging appliances into an outlet that far above a stove or counter is an accident about to happen. To have loose wires dangling from a cabinet to a counter or stove. is dangerous. If a child snags a cord and pulls something down they can be severely scalded. I don't understand why you are not putting outlets where they are normally placed at the back walls between your counters and cabinets. Plugging a microwave into a cabinet outlet is fine, but to plug appliances into an outlet inside a cabinet, above a stove or counter to me is impractical and dangerous. JMHO
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
