Need electrical help
Forum topic by Garyb6 posted 02-07-2009 03:14 AM 1059 views 0 times favorited 5 replies Add to Favorites Watch
View Garyb6's profile
Garyb6
306 posts in 3624 days
02-07-2009 03:14 AM
Topic tags/keywords: question electrical
I am making a dust filter from an old HVAC fan. The fan is a 220V, 2A, 1/3 HP fan with 3 speeds. I am planning to buy a 4 position switch for control. I was at the hardware store today and the switch I was going to purchase was labeled 230V, 3A, 1/4 HP. I didn’t get it because of the 1/4 HP rating. I know I am a little rusty with my electrical theory but what does HP have to do with a switch? HP is calculated using Voltage, current and motor effeciency.
So I think this switch would be OK, but wanted to check with some of you smart guys out there.
Thanks,
Gary
-- Garyb6, “True simplicity does not reveal the tremendous effort it requires.” - Somerset Maugham
5 replies so far
View Scot's profile
Scot
344 posts in 3390 days
#1 posted 02-07-2009 03:21 AM
The amperage is the important thing to look for. The switch you found should work just fine.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
View bendisplays's profile
bendisplays
40 posts in 3394 days
#2 posted 02-07-2009 05:04 AM
Gary,
The rating on the switch is the maximum horse power that it can handle. So if it is rated 1/4 hp, then that is the maximum power the switch can drive.
1/3 hp is higher than 1/4 so the switch will not handle 1/3 hp.
I hope this helps.
Ben
Garyb6
#3 posted 02-07-2009 07:24 PM
OK. One person says yes and one says no. I guess I’ll err on the side of caution and try to find another switch.
Thanks,
Gary
View GFYS's profile
GFYS
711 posts in 3464 days
#4 posted 02-07-2009 07:41 PM
It could be that start amps are figured into the HP rating.
View Al Killian's profile
Al Killian
273 posts in 3746 days
#5 posted 02-08-2009 08:14 AM
Go to a electrical supply place. They will have the proper switch for you.
-- Owner of custom millwork shop
