Materials for Workshop tops
Forum topic by AtlasRook posted 09-26-2014 04:16 PM 1049 views 0 times favorited 6 replies Add to Favorites Watch
View AtlasRook's profile
AtlasRook
25 posts in 1431 days
09-26-2014 04:16 PM
Topic tags/keywords: question jig router
I’ve been looking at trying to build my own router table, and I keep wondering what kinds of materials are out there that people use for table tops in the workshop. I’ve seen some projects use MDF, plywood, melamine, or formica along with some others.
What are some pro’s and con’s for using these materials? Are there others I haven’t heard about?
View Dutchy's profile
Dutchy
2757 posts in 2077 days
#1 posted 09-26-2014 04:26 PM
I use Trespa, with you can compare with formica. Both are HPL (BTW formica is a brand made with melamine). You can buy Trespa in many different thicknesses.
-- https://dutchypatterns.com/
9980 posts in 3556 days
#2 posted 09-26-2014 04:58 PM
One that is easy to overlook is tempered hardboard. It’s
cheap, tough and waxable.
View pintodeluxe's profile
pintodeluxe
5569 posts in 2722 days
#3 posted 09-26-2014 05:18 PM
I use Formica laminated tops for my permanent tools and benches, and white melamine for replaceable or low-use areas.
View Tugboater78's profile
Tugboater78
2729 posts in 2100 days
#4 posted 09-26-2014 05:54 PM
I’ve been using hardboard for my benchtop, with mdf or plywood underneath, it’s pretty durable, and fairly cheap.
One of my work tables here
Haven’t posted as a project yet but posted a blog last night of another here
Like Loren said, it’s waxable, I do glueups on the one and when the glue dries on it I just use a board and scrape it off with no damage.
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
View gfadvm's profile
gfadvm
14940 posts in 2599 days
#5 posted 09-27-2014 12:56 AM
Baltic Birch ply covered with Formica is my choice: lasts forever and easy to clean. White Formica also allows you to write on it in pencil and it comes right off with an eraser or alcohol.
View timbertailor's profile
timbertailor
1594 posts in 1333 days
#6 posted 09-27-2014 02:13 AM
- gfadvm
I agree.
Down here in the south, two pieces of Birch laminated together is recommended to avoid warping due to humidity. It is the most stable. MDF and particle board would be my last choice.
