Best wood for painted kitchen cabinets
Forum topic by BJODay posted 09-26-2014 01:59 PM 11670 views 2 times favorited 18 replies Add to Favorites Watch
View BJODay's profile
526 posts in 1875 days
09-26-2014 01:59 PM
Topic tags/keywords: painted finish kitchen cabinet
My nephew is remodeling his kitchen. They wanted to have painted cabinets. We are considering building to help reduce costs. (They have some custom sizes in mind). I have made plenty of face frame cabinets but I have never built for a painted finish.
What is a good wood to use for a painted finish. I’m thinking poplar or pine. Any thoughts or suggestions are appreciated.
18 replies so far
4906 posts in 2426 days
#1 posted 09-26-2014 02:05 PM
Poplar works very well, so does maple and it’s usually not that much more expensive. I’ve never tried pine and probably never will (clear pine is very expensive around here). I’ll also suggest pre finished plywood for the carcase, really saves a lot of work not having to finish the interior of the boxes.
View BinghamtonEd's profile
2286 posts in 2302 days
#2 posted 09-26-2014 02:29 PM
+1 on the prefinished (1-side for interior) boxes, and I agree on the maple, it’s more durable than poplar. If you have time to wait for a deal to show up, rough cut soft maple can be had on craigslist for $1-2 per board foot. I would save the poplar for drawer boxes and interior pieces that won’t be seen/touched.
1313 posts in 1867 days
#3 posted 09-26-2014 02:29 PM
Poplar and Maple are both good choices. Maple will be much harder, so keep that it mind.
Ditto Fred on the prefinished plywood.
-- The Wood Is Your Oyster
View ChrisK's profile
1934 posts in 3014 days
#4 posted 09-26-2014 02:32 PM
My neighbor does very high end cabinets that are painted 80% of the time and he uses Maple with the melamine plywood for the insides. He also pocket hole joins the sides and bottoms together, no dado’s. I still prefer dado’s to help align the parts and I think they are stronger.
-- Chris K
View jmartel's profile
7741 posts in 2082 days
#5 posted 09-26-2014 02:37 PM
I wouldn’t use poplar. I’m not a fan of it at all with how soft it is. Dents very easily. Use maple.
View Grandpa's profile
3259 posts in 2608 days
#6 posted 09-26-2014 02:59 PM
Maple. Use Varsity maple ply for the carcass.
View Keith Sonefelt's profile
Keith Sonefelt
18 posts in 1283 days
#7 posted 09-26-2014 03:02 PM
We normally used poplar in Dad’s cabinet shop and always had good results with it.
-- "If it's worth doing, it's worth doing right"
View ADHDan's profile
800 posts in 2041 days
#8 posted 09-26-2014 03:14 PM
I built my painted built-in cabinets with basic BORG maple plywood and birch face frames (because birch happened to be on sale at the lumberyard), finished with an airless sprayer. I used poplar for some of the trim in places where it’s not likely to dent – e.g. the mantle shelf frame pieces. I thought it turned out pretty good; pics in my project gallery.
-- Dan in Minneapolis, woodworking since 11/11.
#9 posted 09-26-2014 06:13 PM
I am sorry about the above post. I meant to say Varsity Birch plywood. We get it in my local lumber yard at a decent price. It is finish sanded and paints well. It has more plies than the AC fir and doesn’t show grain through your paint. It is similar but not the same as Baltic Birch.
View timbertailor's profile
1594 posts in 1356 days
#10 posted 09-26-2014 08:29 PM
Birch Plywood.
Very stable over time and less likely to warp in humid conditions.
Maple for the face frames. Durable.
Maple for the doors if you are not on a budget. Maybe just the rails and stiles in Maple and use poplar for the door panels to save some money.
Like you said, it is going to get painted. I just use box clamps and glue to assemble.
-- Brad, Texas,
View DrDirt's profile
4421 posts in 3675 days
#11 posted 09-26-2014 09:03 PM
I’ll echo Fred and some of the others.
Get the PREFINISHED PLY for the carcases. The finish is very durable, and you won’t smell your shelves for months, or have canned goods stick to them.
But Avoid menards tigerply.
remember this is likely a one time shot, you cannot go back and fix this, and want cabinet boxes to last for decades, not months.
For the face frames, poplar is the way to go for painted frames.
View AandCstyle's profile
3003 posts in 2189 days
#12 posted 09-26-2014 11:10 PM
If you intend to make panels in the doors, consider MDF for the panels. It machines well (except for the dust), takes paint well and you don’t need to worry about movement. Also, it costs less than maple or poplar.
-- Art
View MT_Stringer's profile
3160 posts in 3163 days
#13 posted 09-26-2014 11:20 PM
I used poplar to build these face frames for my mom’s cabinets. Note: MDF for the drawer front panels.
And these cabinets for our buffet
And these cabinets for my brother in law’s kitchen and doors and drawer fronts. Plus birch ply for the carcases.
Prefinished Birch for the inside of the buffet and our kitchen cabinets.
Hope this helps.
View DaleM's profile
958 posts in 3316 days
#14 posted 09-26-2014 11:37 PM
Plus one for maple rather than poplar when painting. Poplar grain raises bad when using a water based finish such as latex primer so it requires a lot more sanding between coats. Don’t use pine unless you are going to use Zinsser BIN primer which contains shellac or even the smallest of knots will eventually bleed through the paint. If you do find a deal too good to pass up on poplar, you could seal it first, then sand and prime and the grain won’t raise. Paint looks great over sanding sealer on poplar, but if don’t sand the sealer very well and blow/wipe off all the dust, then the primer won’t stick well.
-- Dale Manning, Carthage, NY
#15 posted 09-27-2014 01:56 AM
Thanks for all the advice,
I’m reluctant to use pine because I’ve had some problems in the past with the face frames distorting while clamped. Sounds like poplar may have similar problems. Maple sounds best. I’ll discuss it with my nephew and his wife and see what they think. I’m happy to help them save money but I don’t want to do it on the cheap.
