Any LJ's use the Rockler Beadlock system? How's it compare to Domino?
Forum topic by Ocelot posted 09-25-2014 03:15 PM 1352 views 0 times favorited 3 replies Add to Favorites Watch
View Ocelot's profile
Ocelot
1975 posts in 2638 days
09-25-2014 03:15 PM
Topic tags/keywords: domino beadlock mortice tenon
I just noticed on the Rocker site their Beadlock system, which I never heard of. It seems like a poor man’s Domino substitute. Have any of you used it?
(I guess I should have looked at the reviews first.)
Now I see there are several review threads for Beadlock.
Thanks,
-Paul
3 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2370 days
#1 posted 09-25-2014 03:24 PM
Hm, interesting, this is the first I’ve seen it. It seems like it would be cheaper and quicker to make a router jig, and make the loose tenon stock on the router table with a roundover bit, then cut to size.
View robdem's profile
robdem
380 posts in 2606 days
#2 posted 09-25-2014 07:36 PM
I have the bead lock system poor mans domino system . Works very well will let you make 3 different size mortise 1/4 3/8an 1/2 inch . Not as fast as the domino takes time to drill over lapping holes . You can either clean them up to make a true mortise or leave them and use there beadlock tenons .
View Loren's profile
10401 posts in 3648 days
#3 posted 09-25-2014 08:06 PM
