Which screws to use
Forum topic by b2rtch posted 09-24-2014 06:10 PM 1040 views 0 times favorited 16 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4863 posts in 3225 days
09-24-2014 06:10 PM
Topic tags/keywords: question
I have a pergola ( gazebo).
On the top of it I have twenty 2×6 lying flat.
Because of the sun , the rain, the snow and so on, these get rapidly deteriorating.
I do not not want to have to climb on the pergola every year especially as I get older so,to protect them, I am getting galvanized steel caps made.
Question: which kind of screws should I use to secure these caps on the 2×6.
I am concerned about electrolysis.
Would Stainless steel be OK?
Thank you.
-- Bert
16 replies so far
View Dallas's profile
Dallas
3599 posts in 2664 days
#1 posted 09-24-2014 06:15 PM
Use a standard galvanized siding screw with a rubber or nitrile seal.
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
601 posts in 3084 days
#2 posted 09-24-2014 06:16 PM
Why aren’t you using regular roofing-siding painted metal.
Not criticizing, just curious
C_PLUS_Woodworker
#3 posted 09-24-2014 06:17 PM
Yep, those are the screws I would use
b2rtch
#4 posted 09-24-2014 06:25 PM
“regular roofing-siding painted metal”
where to find that?
After a while paint peel or deteriorate
-- Bert
Dallas
#5 posted 09-24-2014 06:28 PM
Siding metal isn’t usually painted any more, it is powder coated. That is more effective in stopping electrolysis than paint. It will also last for 50 years or more.
b2rtch
#6 posted 09-24-2014 06:35 PM
Thank you every one
-- Bert
C_PLUS_Woodworker
#7 posted 09-24-2014 06:42 PM
Thanks Dallas…..................so it sounds like we agree the metal sheeting is the way to go
http://www.exteriorproinc.com/blog/bid/343936/Pole-Barn-Metal-Vs-Standing-Seam-Metal
MetalMart in Lehi sells a zillion tons of this stuff. Lots and lots of sales. The also have occasionally cut-offs that are very inexpensive if you can work with the color. Your total amount needed would not be too much of a factor anyway. They will even cut it to exact length for you, so little to no tin-snipping needed. VERY helpful folks as to install, etc
b2rtch
#8 posted 09-24-2014 07:20 PM
Bruce, i do not want to cover the all thing , only the 2×6,individually.
To cover the all thing would easier, faster and cheaper but this is not what I want to do.
Thanks anyway
-- Bert
View Grandpa's profile
Grandpa
3261 posts in 2853 days
#9 posted 09-24-2014 08:04 PM
Bert, most places that sell metal can get it in about any shape you can measure and draw. It will come preformed and all you do is add hole for the screws.
b2rtch
#10 posted 09-24-2014 09:50 PM
Thank you all.
Tonight I bought he screws at HD
-- Bert
runswithscissors
2874 posts in 2202 days
#11 posted 09-25-2014 12:59 AM
Okay, it’s a moot point now, but I was going to say, I don’t think electrolysis is much of a problem in the absence of an electrolyte, such as saltwater. If anyone with experience can refute this, I will stand corrected.
b2rtch
#12 posted 09-25-2014 02:32 AM
runswithscissors, we have problems at work with black pipe fittings screwed in brass valves
-- Bert
Grandpa
#13 posted 09-25-2014 02:47 AM
That is called Galvanic corrosion. Corrosion caused by using dissimilar metals. Bert is correct it will corrode when you do this. I think he is using the incorrect term but then again maybe not. Have a great evening.
View wseand's profile
wseand
2796 posts in 3219 days
#14 posted 09-25-2014 04:32 AM
They both need an Electrolyte to occur, Electrolytic Corrosion requires an applied current and Galvanic doesn’t.
TopamaxSurvivor
18380 posts in 3853 days
#15 posted 09-25-2014 05:38 AM
If it is treated lumber, depending on the age, galvanized may be an issue.
