Forum topic by bhacksaw | posted 09-24-2014 06:20 AM | 1659 views | 0 times favorited | 21 replies | ![]() |
Topic tags/keywords: walnut boards walnut I’m trying to make the Rogowski jewelry box for a friend’s wedding, but I can find 2/4 walnut boards that I want to make it out of. The only thing I’ve found that comes close is the 2/4 board they sell in the little hobby bags at Woodcraft, but I’d have to buy too many bags to make it worth it. I could buy some 4/4 board I’ve seen for sale on craigslist, but I only have a benchtop bandsaw which I did NOT pay an arm and leg for, so I’m not sure if resawing would be a good idea. Also, I don’t have a planer to even it out afterwards. Any ideas? I’m a relatively new woodworker, and the only walnut I’ve worked with was from that woodcraft grab-bag. I like the dark color, but the walnut I’ve seen on craigslist is much lighter. Should I be looking for a specific type of walnut to get that naturally dark color? |
21 replies so far
#1 posted 09-24-2014 06:40 AM |
Maybe you should try searching for black walnut. You might have to go with a veneer. Sometimes, places like Woodworkers Source has samples pieces that might work for you. You might even find a place that will plane it for you. Not sure if WoodCraft or WWSource does that, but you might call them and ask. |
#2 posted 09-24-2014 06:43 AM |
Try contacting The Wood Whisperer and see if he has any for sale, I kid of course. But he might have an idea, and I think he is still active on this site. |
#3 posted 09-24-2014 06:50 AM |
You should be prepared to stain walnut if you want |
#4 posted 09-24-2014 07:58 AM |
Try contacting the folks at Bell Forest and see if they can fix you up. I did see a 5/8 board there, but I would guess not as dark as you want. (They have actual photos of there products.) I think danish dark walnut oil or min-wax dark walnut stain is what you may need to use in the end. By the way, American black walnut will darken with age, while the European walnuts may become paler with exposure. Walnut grows all over the U.S. so you can probably find it at a local small saw mill and get it surfaced to the thickness you want. The issue is that will not be as dark as you want. So you’ll have to stain/oil it. (Apparently the only parts of the U.S. it does not grow are: the southern tip of Florida, the southern tip of Texas, Costal California, and the northern portion of the central high plains.) You can also probably take a 4/4 board to the high school shop or a local commercial wood shop or and have it re-sawn and/or re-surfaced down to the thickness you want. -- -- Cheers, Don K. (Michgan's Kewenaw peninsula) |
#5 posted 09-24-2014 11:37 AM |
I might have some that I can send you. Sometimes I end up with boards that are scant, i.e., thinner than the target thickness, and will not plane out to 3/4”. So, let me see if I have some that I could ship to you in a USPS flat rate box. What are your critical dimensions? What your length and width requirements? -- Danny Located in Perry, GA. Forester. Wood-Mizer LT40HD35 Sawmill. Nyle L53 Dehumidification Kiln. hamsleyhardwood.com |
#6 posted 09-24-2014 11:53 AM |
As for making the walnut dark brown, I have had great success with this method. Summary: I was trying to get it particularly dark, so you may want to adjust the dye and stain colors if you’re wanting it a little lighter.
-- "Man is the only animal which devours his own, for I can apply no milder term to the general prey of the rich on the poor." ~Thomas Jefferson |
#7 posted 09-24-2014 01:00 PM |
I stain it dark brown |
#8 posted 09-24-2014 01:17 PM |
The Woodcraft near me would resaw and plane it if they were asked. Depending on the amount baught there might or might not be a small charge. Ask them. -- Bruce, Boise, ID |
#9 posted 09-24-2014 01:33 PM |
You can also search on ebay for “craft lumber”. It is typically sold in thicknesses of 1/8 to 1/2” and is not as expensive as woodcraft. Alternatively, you could resaw with a handsaw and some patience. -- Brian T. - Exact science is not an exact science |
#10 posted 09-24-2014 02:19 PM |
I had good luck with the 4/4 wood I got from Rockler. It is always on the heavy side. Let me know if you need a 20% off discount code. -- Brad, Texas, https://www.youtube.com/user/tonkatoytruck/feed |
#11 posted 09-24-2014 02:43 PM |
Walnut gets quite a bit darker when finish is applied. Whatever you do, try it out first on some scrap before you do it on the final workpiece. Alternatively, try going to a cabinet shop or something and ask them if they can plane it for you for some money. -- The quality of one's woodworking is directly related to the amount of flannel worn. |
#12 posted 09-24-2014 03:40 PM |
I had some 1” planed and straight stock that I was able to resaw and after planning out the saw marks, worked out to just a little under 7/16”. This I used to make a tool box for my son for Christmas and when finished with rattle can lacquer, ended up looking great. The real question is whether it will stand the test of time as he has a tendency to be a bit rough on things at times. |
#13 posted 09-24-2014 07:07 PM |
Thanks for all the great tips, everyone! So much to respond to: Bill: Veneer is out as the box will feature proud, slightly chamfered finger joints. I posted to the WW’s page (he’s who gave me the idea to build this) but no response so far. CharlesA: that is a beautiful bench! Bruce: I got a curt “No” when I asked at my Woodcraft. Some of the guys who work there are Grade A human beings, some of them are humps. Apparently the latter answered the phone. Brian T.: great tip. Lots of wood, but nothing that fit exactly. Brad: I would love that Rockler discount code, please. Danny, that would be great! Here’s what I basically need (all size are final dimensions, so go a little bigger, please): (2) 2.25×12.125 front/back I tried looking up how much those flat rate boxes, but I couldn’t nail down anything solid. Let me know if you find it. I think there’s a box they refer to as “board game” sized which is the only one I could see that would fit the board lengths.
#14 posted 09-24-2014 07:23 PM |
He is a Boy what do you expect. :) |
#15 posted 09-24-2014 09:20 PM |
Board game box is 23 3/4” x 11 3/4” x 3” -- Improvise.... Adapt...... Overcome! |
Forum | Topics |
Woodworking Skill Share
12035 |
Woodturning
2110 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1372 |
Finishing
4910 |
6698 |
28076 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1421 |
Wood & Lumber
6237 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
