vertical drawer slides?
Forum topic by TheEverymanShow posted 09-24-2014 05:01 AM 5751 views 0 times favorited 6 replies Add to Favorites Watch
View TheEverymanShow's profile
TheEverymanShow
2 posts in 1340 days
09-24-2014 05:01 AM
I am looking for a type of drawer slide that will work in a vertical application. I am wanting to put a hidden compartment inside a mantle and to access it I want to pull down on a door and then the compartment slide down from inside. The lowering of the compartment needs to be somewhat slow and contained but I also want it to have a positive lock when it is pushed all the way in.
Does anybody have any ideas? I appreciate the help.
Thank you
View Loren's profile
10396 posts in 3647 days
#1 posted 09-24-2014 05:32 AM
Any ball bearing slide will work but you want a soft
opening under force of gravity and that probably
does not exist. You’ll have to engineer a weight
or spring system yourself to slow the travel.
View GrandpaLen's profile
GrandpaLen
1650 posts in 2271 days
#2 posted 09-24-2014 01:35 PM
You didn’t mention how much weight you are lowering and raising, but I’m imagining a self winding/tensioning spring.
...think, garage door counter balance type spring, window shade, home movie screen and combine with full extension drawer slides.
...just a thought
Work Safely and have Fun. – Grandpa Len.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View MrRon's profile
MrRon
4769 posts in 3242 days
#3 posted 09-24-2014 05:43 PM
I would use something similar to the hardware used on vertical sliding windows. You might be able to get an old window and adapt the hardware for your application. The hardware is probably available, buy I know not where.
View Dallas's profile
Dallas
3599 posts in 2486 days
#4 posted 09-24-2014 06:09 PM
Electrical linear actuator
You can find them cheaper than these people sell them.
http://www.motioncontrolproducts.com/electric-actuator/mxe-series-linear-actuator.php?cat=5
I have one I took off an old 12’ satellite dish that will extend 30” I was going to use it to make a television slid out of sight into a cabinet when I’m able to do more.
TheEverymanShow
#5 posted 09-24-2014 06:19 PM
Thanks everyone for the ideas and suggestions
View creativecarpenter's profile
creativecarpenter
1 post in 1297 days
#6 posted 11-05-2014 01:29 PM
I would use drawer slides along with a gas spring to lift or lower. They are pretty cheap, and are made in a wide range of sizes and weight range. There are even some that are dual action lifting and lowering. It will lower your project at a quiet controlled speed. All you would need to do is design a trigger system to hold your project in the closed position. Then when released the compartment would lower slowly.
