Saw marks?
Forum topic by skogie1 posted 09-24-2014 12:57 AM 995 views 0 times favorited 6 replies Add to Favorites Watch
View skogie1's profile
skogie1
117 posts in 1387 days
09-24-2014 12:57 AM
Topic tags/keywords: walnut
This is some walnut that I’ve brought down to thin stock for the purposes of inlay. I’m going to cut a pattern out of this. I’ve never done this before. What are those horizontal light bands running across the boards? Are they saw marks? I’ve used the belt sander with 60 grit and then followed up with the orbital sander working up to 220, but they won’t go away.
I wet the wood with mineral spirits to show them.
Thanks in advance.
View wseand's profile
wseand
2796 posts in 3066 days
#1 posted 09-24-2014 01:29 AM
Looks like planer marks. Are they raised, it’s hard to tell from the pic? Since you can’t sand it out, it may just be the grain causing it to look like there is something wrong. It looks like from the pic it is just that one piece, I would gather it is just the grain.
View richardwootton's profile
richardwootton
1699 posts in 1979 days
#2 posted 09-24-2014 02:03 AM
To me it looks like a little bit of curly grain.
-- Richard, Hot Springs, Ar -- Galoot In Training
18351 posts in 1880 days
#3 posted 09-24-2014 02:09 AM
My guess is from the belt sander. A spot on the belt that is thicker than the rest can cause a divot as it comes around each time. Probably where the two ends are glued together. I would say send them thru a planer or use a card scraper.
View ShaneA's profile (online now)
ShaneA
6956 posts in 2622 days
#4 posted 09-24-2014 02:21 AM
It kind of looks like figure to me too. Hard to tell from the photo. Can you feel them?
View JayG46's profile
JayG46
139 posts in 1882 days
#5 posted 09-24-2014 02:31 AM
Agree with ShaneA. If you can’t feel them, congratulations, you have some curly walnut!
-- Jay Gargiulo, Naples, FL www.swallowtailwoodcraft.com "Once you understand the way broadly, you can see it in all things."- Miyamoto Musashi
skogie1
#6 posted 09-24-2014 03:20 AM
It’s curly. I sanded the hell out of an area that’s not going to be used and it didn’t change. And no, it’s not raised. This panel is super flat and smooth now. Thanks for the input everyone!
