Stump projects
Forum topic by Zaby posted 292 days ago 616 views 0 times favorited 10 replies Add to Favorites Watch
View Zaby's profile
Zaby
3 posts in 292 days
292 days ago
Topic tags/keywords: stumps tree stumps amateur table stool rustic outside humor resource question oak pine ash shaping finishing
I am an AMATEUR – enough said. Can anyone give me any advice on working with tree stumps – specifically with the following – I just want to make some stools and tables.
  • what are the best tree stumps to work with
  • should the bark to left on
  • Oil or water based polyurethane
  • plans
Another question – I have a large slab from a tree trunk about 3” thick and it has cracked – wanted to use as a table top – would it still be usable – whats best way to put back together. (It’s from a lace bark elm tree).
Thanks in advance – any advise is very welcome.
View lew's profile
lew
4486 posts in 650 days
292 days ago
There are several craftsman here at LJs that produce this type of furniture. Try a search to locate their work.
View Dragon's profile
Dragon
6 posts in 293 days
291 days ago
Tell me a bit more about what it is you’re wanting to do. I work with stumps and logs almost exclusively and by no means am I an expert but I have gotten a few chains worn out cutting them.
View Zaby's profile
Zaby
3 posts in 292 days
291 days ago
Dragon,
I have two projects that I’d like to work on.
FIRST PROJECT I would like to make a table out of a tree stump. I have stumps from an oak tree and lace bark elm. I’m trying to find out if I should take the bark off the elm – read somewhere that that’s better but another site said I can spray it with water based polyurethane. Is water based polyurethane the best to use on tree stumps.
Second Project
I have a 3 1/2 inch slab of a tree – the diameter is approximately 3 1/2 feet and I’d like to make a small table for my patio out of this piece. Unfortunately the slab has separated into three pieces. Can this be put back together and it so – how and what is the best way to do it.
I thank you greatly in advance for my obviously amateur questions. My sincere thanks
Dragon
6 posts in 293 days
290 days ago
PM sent…......
View Cantputjamontoast's profile
Cantputjamontoast
172 posts in 327 days
277 days ago
The Butterfly joint was on page 110 of FWW”on Joinery”
isbn 0-918804-25-6
-- "Not skilled enough to wipe jam on toast!"
View CAMERONGAGNON.com's profile
CAMERONGAGNON.com
129 posts in 303 days
277 days ago
Hey zaby. I’ve cut a few logs so far. I know that if you want to keep the bark on, it is best to find a log that was from a tree that was cut while it was dormant. example winter time. The cambium has less water during this time and the bark seems to stay stuck naturally. No varnish needed.
Next project. If the slab has already broken, most of the stress should be gone now. Basically you could just biscuit joint it back together. You will have to sand quite a bit though.
-- "Safe woodworking isn't just about avoiding injury, it is also about avoiding extinction." CKG
View PG_Zac's profile
PG_Zac
152 posts in 283 days
274 days ago
Zaby,
I cut slabs from logs, and I would recommend that, as far as possible, you should remove the bark before cutting. There is often a load of dust and sand integrated into the bark, and that dulls your cutting blade quite quickly. Note also, that Palm trees generally have sand embedded all the way to the heart of the trunk. A friend of mine charges for a new chain in every job they quote to fell a palm. As for keeping the bark on the slab after finishing, I haven’t personally found a way that works for me. My slabs have always shed their bark some months after I thought they’d be fine.
Technically speaking, there is no finish better than the other for slabs vs boards. What you’d like to use on a board, you use on a slab.
Your split slab – For joining the parts back together, you would need to treat a crosscut slab differently than a slab along the grain. You will almost definitely not be able to rejoin a crosscut disk invisibly due to the difference in shrinkage around the rings vs across the rings. When you place the pieces against each other, you’ll find that their seems to be a “slice of pie” missing. You cannot recover that.
View rtb's profile
rtb
679 posts in 608 days
274 days ago
I don’t think that biscuits are really strong enough to tie these pieces back together, large ( 1/2 ” or more set deeply in each side would be necessary. As ZAC noted you may well have unclosable cracks but these could be filled in any number of ways but will be very visible. You should consider Gorilla glue or tightbond III and spar varnish if you want this for out side use.
View TexPenn's profile
TexPenn
284 posts in 582 days
127 days ago
Hows it going?
-- Ted, TX or PA www.around-the-bend.com
Dragon
6 posts in 293 days
127 days ago
It’s going…........hot as you know what here and not much in the way of rain to cool things down. Honestly, I’ve been working in the garden pretty much and haven’t had any free time to get down to any serious woodcrafting lately.
