Harbor Freight 1HP dust collector - can it be mounted sideways, intake down?
Forum topic by rickswood posted 09-22-2014 11:09 PM 1250 views 0 times favorited 4 replies Add to Favorites Watch
View rickswood's profile
rickswood
1 post in 1311 days
09-22-2014 11:09 PM
Topic tags/keywords: hf dust collector question
Want to use 1HP HF dust collector mounted sideways allowing intake to position directly above Thein baffle outlet for better airflow. Has anyone encountered any problems with the motor/impetter bearings becoming prematurely worn, or failing outright?
View RRBOU's profile
RRBOU
176 posts in 2260 days
#1 posted 09-22-2014 11:13 PM
I have had mine mounted this way for over a year and no problems so far. Did not even think it would be a problem.
-- If guns cause crime all of mine are defective Randy
View MrRon's profile
MrRon
4720 posts in 3212 days
#2 posted 09-23-2014 08:43 PM
By shifting the motor axis from horizontal to vertical, may put more “thrust load” on the bearings. That may shorten the life of the bearings.
View cpd011's profile
cpd011
90 posts in 3206 days
#3 posted 09-23-2014 09:06 PM
I’ve had mine mounted that way for a couple years with no problem. mine is mounted directly to a thien separator sitting on top of a fiber barrel.
View comboprof's profile
comboprof
277 posts in 1703 days
#4 posted 09-23-2014 09:09 PM
I ve had mine mounted that way for a couple years with no problem. mine is mounted directly to a thien separator sitting on top of a fiber barrel.
- cpd011
Pictures?
-- -- Cheers, Don K. (Michgan's Kewenaw peninsula)
