I got this old wood jointer and got it in a lot of planes that also included a Stanley 113, a No. 4 handyman, and an unmarked block plane. I paid $35 for the lot which would have been a steal for the 113 alone so the rest is just gravy.
The more I look at this wood plane the more I want to do something with it. It is a New York Tool Co. and I think it dates to the 1890's. It is 26", it has a few cracks but none of them go all the way through and it is quite square. From what I've read they aren't too sought after but are mostly purchased to be users. The problem is that it doesn't have a blade or wedge. I have done a little research and making a wedge shouldn't be too difficult but I'm not sure what to do about a blade. The opening of the mouth is 2 ½" so I assume putting a 2" blade in it would give it too much slop and would give me problems. Should I look for a blade that is 1 ½' and plan on filing it down a bit to fit or should I look for something that is 2 ¼-2 3/8"? I appreciate your input. Thanks!
Sorry, that is my inexperience showing. It looks like the original blade didn't fit the full width of the mouth. From this photo you can see that there is a lot more aging on the sides than in the middle. That is what led me to question whether or not the plane was designed to use a blade around 2 1/4". Should I look to put a wider blade in it then?
Unless you are set on buying a new blade, Old blades are going to be rare without a plane…you are probably just as likely to find one of the more common 22" wooden planes at a flea market for a similar price(20-30) and just use the blade from it…the blades on those should be the size you need.
Tapered single, or double irons come up on ebay pretty often. There is one up right now for $25, but its a bit thin at
2 1/8th. Lee valley does sell tapered plane blades aswell, however at $40 for the 2 3/8 iron its pretty pricey. If you can find another similar plane in disrepair with a good iron you can usually get them for $10 to $15. Coffin smoothers with a half inch mouth come to mind… But I've seen good tapered irons on ebay for under $20 bucks. That being said, a similar plane to yours at a flea market would also go for about 20 bucks.
I dunno, I guess it depends on where you are. I find the irons for these almost as often as I do the planes themselves. I would also suggest keep looking for an iron. You're much more likely to find a complete plane in better condition for a good deal first, but don't let that stop you if you want to make a complete plane out of this one.
I should say I was not considering online…I do a lot of shopping around at flea-markets and antiques stores and see those 22" Wooden planes all the time. I use one for my primary jointer, and it works fantasticly with that thick tapered iron and matching chip-breaker. Mine is from Ohio tools Co.
I found a decent blade for $12 bucks so I started to work this plane over a bit. There are a few superficial cracks that don't affect the integrity of the plane but I'd like to seal them up so they don't become problems in the future. Does anyone have suggestions on how to correct this? Right now I am leaning towards CA glue but would definitely do something else if there is a better option. Thanks!
I was distracted with a few other projects but I was able to play with it a little this weekend. I put some CA glue in the cracks just to make sure that they don't spread in the future. I cleaned up the body with boiled linseed oil and it looks pretty good. I made a wedge that works well but I'm not sure how to finish it. I decided to use maple because I have plenty laying around. It doesn't look all that great with the body of the plane. I can't decide if I want to try to stain and antique the wedge to try to make it match or if I should let it be what it is and enjoy the contrast of the woods. What do you think?
Be careful finishing the wedge. Keep in mind its held in place with friction, so keep the contact points rough and clean.
I would leave the contrast, unless you think you can really make it match. Maple to beech would be tough.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
