Cherry Log - How would you have it milled?
Forum topic by gts78 posted 09-22-2014 02:53 PM 1437 views 0 times favorited 18 replies Add to Favorites Watch
View gts78's profile
gts78
12 posts in 1359 days
09-22-2014 02:53 PM
Just looking for some suggestions here. My parents recently took down a wild cherry tree and told me I could have the log. I need to get it off their lot and have help lined up for this week.
I plan on having it milled and kiln dried but have no specific projects in mind, but anything I would do would like be on the small side (turnings, mayne an end table, etc.).
My initial thought was to have half of it cut to 8/4 and the other half 5/4.
If it was your decision how would you have it milled?
Thanks.
Greg
18 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2361 days
#1 posted 09-22-2014 05:28 PM
4/4
View Don W's profile
Don W
18717 posts in 2567 days
#2 posted 09-22-2014 05:36 PM
How big is the log?
gts78
#3 posted 09-22-2014 06:34 PM
Duh, forgot to say how big the log is. It is just about 14’ long and 15 or 16” in diameter
View Dallas's profile
Dallas
3599 posts in 2487 days
#4 posted 09-22-2014 06:43 PM
Is that 16” with bark or without? That could make a difference as small as it is.
I would make two 7’ logs, cut one into as thick a slabs as possible and turn the other one into 5/4 slabs.
Remember, you really don’t want to use the core so if you slab it all the way you’ll probably have a couple of slabs that need to have the core cut out of or you’ll see severe cracking that can travel all the way across the good wood to the edge.
Don W
#5 posted 09-22-2014 06:43 PM
I’d tell the sawyer to cut it for the most optimal cuts, with your initial thoughts in mind.
Another thing to think about is saving some live edge if you’d want it.
View pmayer's profile
pmayer
1028 posts in 3065 days
#6 posted 09-23-2014 12:26 AM
I’d probably go 80% 4/4, and 20% 8/4, +/-.
View gfadvm's profile
gfadvm
14940 posts in 2690 days
#7 posted 09-23-2014 01:18 AM
I d probably go 80% 4/4, and 20% 8/4, +/-.
- pmayer
I second that motion.
View WDHLT15's profile
WDHLT15
1744 posts in 2476 days
#8 posted 09-23-2014 01:20 AM
A couple of 8/4 boards for table legs. The rest 4/4. Like Dallas said, the pith core will crack and split.
gts78
#9 posted 09-23-2014 01:43 AM
Thanks, all.
Dallas, making two 7’ logs is the first thing I was planning on doing.
The 16” is including the bark, I believe.
Even if it only ends up being 12”-14” diameter without the bark I can’t really complain. It is free lumber. This will also be my first experience having a log milled so at the very least it will be a good learning experience for me.
View buildingmonkey's profile
buildingmonkey
242 posts in 1547 days
#10 posted 09-24-2014 02:50 AM
Try to get the log sawn while you are at the mill. It is a fun experience.
-- Jim from Kansas
View CharlesA's profile
CharlesA
3322 posts in 1797 days
#11 posted 09-24-2014 02:54 AM
If, like most of us, you use 3/4” wood primarily, then go 4/4. If you like to use 1” thick a fair amount, you might do 5/4. OF course, you’ll get more 4/4 planks than 5/4. I kind of like 5/4 because I try not to always use 3/4”.
View nicksmurf111's profile
nicksmurf111
367 posts in 1450 days
#12 posted 09-24-2014 03:16 AM
Hopefully they don’t charge you an extra fee for a small job. I know one of the larger mills around here does, but I found a relative of an acquaintance who had a mill that gave me a good price to cut some cherry up last year (plane sawn on a circle mill). I just let my 4/4 stock air dry for a year in the back of my garage. Some of the boards are really hard to joint and plane at 4/4 to get 3/4 boards and I wish they were a little thicker.
Maybe you can let them sit a few weeks, while you try to acquire another tree, and take more than one? Just an idea.
Also, before you cut them to 7’ ask them how far apart the dogs are on their mill.
-- Nicholas
gts78
#13 posted 09-24-2014 03:54 AM
Charles, I am pretty much a new woodworker so I haven’t really developed a preference for one thickness over another. At this point I’m leaning towards going with two slabs of 8/4 and the rest 4/4. I plan on talking to the sawyer first though once he sees the log to see what he suggests to make the most of the log.
Nicholas, I asked if they have a minimum and told them how big the log is. They said they do not have a minimum and quoted me $0.28/ bd.ft to cut it.
I am taking it to the mill tomorrow if all goes well. I am hoping they can cut it while I am there. Should be fun.
WDHLT15
#14 posted 09-24-2014 11:44 AM
Commercial hardwood is typically rough sawn at 1 1/8” thick for 4/4 lumber. Be sure that the sawyer adds the extra 1/8”. Makes a big difference when planing to 3/4” finished thickness. 8/4 would be 2 1/8” thick.
CharlesA
#15 posted 09-24-2014 11:52 AM
Local sawmills around here for 4/4 is pretty close to 1”.
