Full or thin kerf
Forum topic by joshuam39 posted 09-22-2014 05:06 AM 1760 views 0 times favorited 26 replies Add to Favorites Watch
View joshuam39's profile
joshuam39
62 posts in 1618 days
09-22-2014 05:06 AM
I was going to get a Freud Premiere Fusion blade for my Bosch 4100 table saw. I am not sure if I should get a full or thin kerf blade. I understand the thin is better for weaker powered saws. Is the Bosch powerful enough to handle the full kerf? Is there any other advantages of the thin kerf? I was leaning toward the full kerf.
-- Let's go Pens!
26 replies so far
View wseand's profile
wseand
2796 posts in 3278 days
#1 posted 09-22-2014 05:48 AM
I have the 4100 and use the Thin Kerf and can’t be more happy with it. A truly well made and efficient blade. Put a Thousand BF through it and it keeps going. Barley need to clean it, it still puts a nice smooth cut edge on. . I don’t have the Full Kerf so I can’t say much about it.
View splatman's profile
splatman
586 posts in 1636 days
#2 posted 09-22-2014 06:00 AM
Thin kerf = Less wood turned into sawdust.
View knotscott's profile
knotscott
8177 posts in 3612 days
#3 posted 09-22-2014 09:31 AM
A full kerf blade tends to be more stable, but is 33% wider than a TK, and requires proportionately more effort from the motor. Thin kerf is easier on the motor, so should help with longevity. TK also consumes less wood, makes less noise, and makes less saw dust (as mentioned). Either will work, but I’d lean toward the TK for the sake of the motor.
View bigblockyeti's profile
bigblockyeti
5314 posts in 1957 days
#4 posted 09-22-2014 11:47 AM
For a portable saw, I’d lean toward a thin kerf. Any portable saw will handle a sharp full kerf blade, but as mentioned you’re turning more wood into dust and your feed speed is going to be proportionately reduced. A good thin kerf blade has few drawbacks, the main one being reduced ability to shave a little off one dimension without the blade being fully engaged in the wood as it will tend to flex as it takes the path of least resistance. I use a 50T full kerf on my 3hp cabinet saw 99% of the time. The only reason for me to switch is when I’m doing several thin pieces where the wood savings begins to really ad up, or when making many cuts in something particularly expensive.
View paxorion's profile
paxorion
1107 posts in 2282 days
#5 posted 09-22-2014 01:13 PM
I put a TK blade into my Dewalt saw to ensure that it doesn’t affect the riving knife’s ability to operate. I believe all job site saws that meet the splitter/riving knife regulations are spec’d to support a certain range of thin kerf blades (3/32”/0.94” thick w/ a ~0.71” plate thickness). I actually shyed away from the Freud Premier Fusion TK because the kerf thickness (0.91”) was too close to my Dewalt’s riving knife.
-- paxorion
View timbertailor's profile
timbertailor
1594 posts in 1661 days
#6 posted 09-22-2014 02:06 PM
The Thin Kerf Premium Fusion Freud Combination blade is all I use any more.
Great blades at a great price.
View Loren's profile
10477 posts in 3884 days
#7 posted 09-22-2014 03:45 PM
I would recommend a thin kerf on a portable saw like that
unless all you want to cut is 4/4 stock in which
case a full kerf is probably fine. You can get blade
stabilizers that help cut quality a bit by suppressing
vibration. I used them with thin kerf blades for
several years before I got my first cabinet saw
and started using full kerf blades for everything.
View distrbd's profile
distrbd
2252 posts in 2683 days
#8 posted 09-22-2014 03:54 PM
I think some day in the future you should try a full kerf blade just to see how it cuts and how your table handles the extra weight,you will never know for sure if you like it unless you try it.
-- Ken from Ontario, Canada
Rick Dennington
6348 posts in 3431 days
#9 posted 09-22-2014 04:13 PM
I’ve got about 10 blades, both tk and wf…... I run all of mine on a 5 horse saw,and a 3 hp saw, so I really can’t justify an answer here, other than to say that you might want to try both at some point…Could be that you might update to a bigger saw, and then you’d have both to try….........!!!!!!!!!!!!!!!!
-- " At my age, happy hour is a crap and a nap".....!!
joshuam39
#10 posted 09-22-2014 05:43 PM
Seems everyone is in favor of the thin kerf. I figured a full kerf would be more durable and give more consistent cuts. But, perhaps in light of the fact that I am using a portable saw, the thin would be better. A cabinet saw is on my wishlist, but I won’t be getting one any time soon.
-- Let's go Pens!
View ChrisK's profile
ChrisK
2017 posts in 3318 days
#11 posted 09-22-2014 06:49 PM
I have been using Freud’s thin kerf blades in my table saw for 6 or more years. I love them. You can feel the difference between the full and thin kerf. The thin lets you cut the thin stuff a little quicker and cut thicker harder woods than you could otherwise.
-- Chris K
distrbd
#12 posted 09-22-2014 06:57 PM
The only way I could have cut a slab of 2” by 20” Ash on my table saw(with relative ease) was to use a full kerf Freud LM72 blade.
My table saw has a 1 hp motor.tried the tk blade and it burnt the wood ,almost damaged/warped the blade.
joshuam39
#13 posted 09-22-2014 07:13 PM
How many HP is a 15 amp motor anyway? I’ve never seen a clear answer for this.
-- Let's go Pens!
knotscott
#14 posted 09-22-2014 09:18 PM
How many HP is a 15 amp motor anyway? I ve never seen a clear answer for this.
- joshuam39
It can vary depending on the parameters of the particular motor, but 15 amps @ 120v is generally roughly 1-1/2 realistic usable horsepower. You might see peaks of 2hp or greater for extremely short bursts, but claims of significantly more than that are very misleading.
knotscott
#15 posted 09-22-2014 09:26 PM
- distrbd
Something else was wrong with that particular TK blade or something else in the equation was amiss (dull blade, dirty blade, warped, bent, wrong tooth configuration, poor fence alignment, etc). The fact the blade is 25% thinner won’t be the cause of burning.
I’ve ripped upwards of 3” on several occasions on multiple saws using several different TK blades without a problem, and have read of several others doing it also. I bought an LM72 at Freud’s recommendation for my contractor saw, and it labored the motor quite a bit. The TK version of the same blade, the LU87 ripped much more effortlessly on the same saw.
