wiring my saw
Forum topic by tbart posted 09-21-2014 08:59 PM 838 views 0 times favorited 7 replies Add to Favorites Watch
View tbart's profile
tbart
3 posts in 1306 days
09-21-2014 08:59 PM
I need some help with the wiring of my new saw. I have a 220 volt saw that I want to wire direct into a box. I have 3 wires on the single phase motor and the colors are Red, Green, and Black. The box that the saw will connect to has a 30 amp fuse in it. If anyone can guide me on the hook up that would be great. I went with the box rather than a plug in because I want to be able to lock the box out from my grandkids that my want to turn the saw on. Thanks
7 replies so far
View Rustlerrd's profile
Rustlerrd
1 post in 1306 days
#1 posted 09-21-2014 09:36 PM
Number 1, I would suggest a receptacle and plug, and a locking paddle switch. I am guessing there is also a ground.
Number 2. Is the circuit you are using a 30 amp 220?
Number 3. Is the wire from the circuit 10 guage?
If # 2 and 3 are yes and you agree to go with #1 you will be fine, but for your safety if you are uncertain please hire an electrical contractor, if you have any concerns or questions.
I am assuming that red is 120. Black is 120. And green is ground on your motor. This is based on what I have seen on other motors, but I AM NOT an electrician.
The receptacle may have red, whit, black.
Please take care
-- Bill, Cottonwood Heights, UT
4949 posts in 2456 days
#2 posted 09-21-2014 09:36 PM
The green wire will be the ground, and the red and black wires are the 2 hots.
View TheFridge's profile
TheFridge
9249 posts in 1449 days
#3 posted 09-21-2014 09:46 PM
If it’s not within 25’ and within sight of the panel you need a receptacle and plug.
View BoardSMITH's profile
BoardSMITH
121 posts in 2227 days
#4 posted 09-21-2014 10:05 PM
Call an electrician! Pay a professional and have it done properly and safely.
-- David www.TheBoardSMITH.com
tbart
#5 posted 09-21-2014 10:33 PM
ok, great help. Thank you
View bonesbr549's profile
bonesbr549
1531 posts in 3030 days
#6 posted 09-21-2014 10:42 PM
I did not quite get from your post what is the amp is required. You said 30 amp fuse but on what the motor? If it requires 30A be sure your outlet, plug, and cable and breaker match! 30A load requires 10AWG wire. As other said you have two hots and the green is ground (no neutral)
good luck.
View TheDane's profile
TheDane
5399 posts in 3626 days
#7 posted 09-21-2014 10:45 PM
Put a plug on it and add a receptacle that is serviced by a breaker … you can still kill the breaker and lock the breaker box.
