Raised Pine Wood Grain
Forum topic by rantingrich posted 09-20-2014 08:17 PM 5934 views 0 times favorited 4 replies Add to Favorites Watch
View rantingrich's profile
rantingrich
372 posts in 1579 days
09-20-2014 08:17 PM
Topic tags/keywords: raised grain pine question rustic
I want to age/distress some pine wood for a few projects.
I want to raise the grain like you would see on some engraved signs.
Not as liberal as that but enough to raise the grain like you might see on some old weathered wood.
Is there any other way to do this other than SANDBLASTING, Which I can not find much information on.
I would like to raise the grain enough for any one to notice. Would like to raise it to where it would be smooth and not require any or much sanding.
If sand blasting is the way, what kind of equipment would I need and what type of “media” would best work for me? Sand Soda Walnut shells Glass beads, steel shot?
I have tried using a metal wire wheel on a drill but it IS NOT SMOOTH at all and leaves unattractive scratches.
Any advice
Rich
-- Rich
View RogerM's profile
RogerM
799 posts in 2633 days
#1 posted 09-21-2014 02:45 PM
I have had a lot of success with burning pine and similar woods with a propane torch then wire brushing it. The more knots the better is quite unique and attractive. finish with a stain to darken and/or use polyurethane (wipe-on works fine) to seal it. Send me a message if you would like a photo of it or would like to discuss the technique.
-- Roger M, Aiken, SC
19574 posts in 2090 days
#2 posted 09-21-2014 02:49 PM
You might try something like these. I’ve used them before, but not for your exact purpose. The idea is that the wheel removes the softer grain and leaves the harder part.
http://www.amazon.com/Dico-50-4-Flap-Assorted-Brushes/dp/B001F527F0/ref=pd_sim_hi_3?ie=UTF8&refRID=18CJWF6YF87QFVSXN0DD
View Loren's profile
10477 posts in 3882 days
#3 posted 09-21-2014 03:06 PM
Put it outside in the sun and hose it down once
a day. This will, I think, result in a sustained raising
without an ugly chewing away of soft fibers. You
may want to coat the ends of the boards with
glue to guard against end checking.
Heat lamps or a furnace would also probably work.
I have observed a lot of wood aging in the sun
and this moisture/drying cycle thing is my theory.
I live in a dry climate and if the wood doesn’t get
wet it doesn’t weather near as much in the sun
alone.
In any case, you can only “raise” the grain so far.
Beyond that point you’ll have to do something
to cut back the unraised grain.
View Clint Searl's profile
Clint Searl
1533 posts in 2595 days
#4 posted 09-21-2014 03:34 PM
I sand blast it.
