Tool Definitions
Forum topic by woodsmithshop posted 1566 days ago 531 views 1 time favorited 3 replies Add to Favorites Watch
View woodsmithshop's profile
woodsmithshop
918 posts in 1714 days
1566 days ago
Topic tags/keywords: humor
I thought you guys might like a chuckle or two!
Subject: Tool Definitions
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, destroying the window which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and
hard-earned sanding calluses from fingers in about the time it takes
you to say, “Oh sh—...”
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you
die of old age.
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle.
It transforms human energy into a crooked, unpredictable motion, and the
more you attempt to influence its course, the more dismal your future
becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads.
If nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
WELDING GLOVES:
Heavy duty leather gloves used to prolong the conduction of
intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in
your shop on fire. Also handy for igniting the grease inside the wheel
hub you want the bearing race out of.
TABLE SAW:
A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have
installed your new brake shoes, trapping the jack handle firmly under
the bumper.
EIGHT-FOOT LONG YELLOW PINE 2 X 4:
Used for levering an automobile upward off of a trapped
hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR:
A tool ten times harder than any known drill bit that snaps
neatly off in bolt holes thereby ending any possible future use.
BAND SAW:
A large stationary power saw primarily used by most shops to cut
good aluminum sheet into smaller pieces that more easily fit into the
trash can after you cut on the inside of the line instead of the outside
edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything
you forgot to disconnect.
CRAFTSMAN 1/2×24-INCH SCREWDRIVER:
A very large pry bar that inexplicably has an accurately
machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS:
See hack saw.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids and for
opening old-style paper-and-tin oil cans and splashing oil on your
shirt; but can also be used, as the name implies, to strip out Phillips
screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common
slotted screws into non-removable screws.
PRY BAR:
A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts
adjacent to the object we are trying to hit.
MECHANIC’S KNIFE:
Used to open and slice through the contents of cardboard cartons
delivered to your front door; works particularly well on contents such
as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially useful
for slicing work clothes, but only while in use.
DAMMIT TOOL:
Any handy tool that you grab and throw across the garage while
yelling “DAMMIT” at the top of your lungs. It is also, most often, the
next tool that you will need.
-- Smitty!!!
3 replies so far
View PurpLev's profile
PurpLev
7749 posts in 1817 days
#1 posted 1566 days ago
Thanx! that was super.
View bowyer's profile
bowyer
340 posts in 1564 days
#2 posted 1564 days ago
Don’t forget the “Wonder Tool” .... I wonder where that tool is???
-- If at first you don't succeed...Don't try skydiving
View brianinpa's profile
brianinpa
1809 posts in 1891 days
#3 posted 1563 days ago
I liked my wife’s definition for “paint scrappers” – my set of chisels. I have since hid my chisles from her.
