Delta Rockwell 28-200 bandsaw
Forum topic by skogie1 posted 09-19-2014 03:44 PM 2204 views 0 times favorited 10 replies Add to Favorites Watch
View skogie1's profile
skogie1
117 posts in 1363 days
09-19-2014 03:44 PM
Looking at possibly buying an old 28-200 for $200. It looks in pretty good shape. Needs some scrubbing. Any thoughts on this machine? Thanks.
10 replies so far
View JayT's profile
JayT
5633 posts in 2211 days
#1 posted 09-19-2014 04:58 PM
That’s the classic and much copied 14in cast iron bandsaw design. It’s a solid design and machine, which is why so many knockoffs were made. If one popped up in my area for $200 in working shape, I’d snap it up in a heartbeat.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2370 days
#2 posted 09-19-2014 05:02 PM
That’s a good saw (I have an old Delta 14”), and $200 seems reasonable. Is he/she asking $200? You may be able to get it for less. If it fires up and runs well, inspect the saw once over real well to make sure nothing is missing/broken. Seems like a fair deal if it’s good shape. I paid $125-$150 for mine, but it was the guy’s ex-father-in-law, so he probably didn’t really care about it, and he knew nothing about bandsaws.
View nicksmurf111's profile
nicksmurf111
367 posts in 1451 days
#3 posted 09-19-2014 05:23 PM
GET IT NOW!
-- Nicholas
skogie1
#4 posted 09-19-2014 05:25 PM
Thanks everyone
View Chris208's profile
Chris208
239 posts in 2270 days
#5 posted 09-20-2014 05:24 AM
Check the castings for cracks!!!
View GrizzlyBagWorks's profile
GrizzlyBagWorks
91 posts in 1591 days
#6 posted 09-20-2014 07:39 PM
I purchased a 28-200 several months ago for what I thought was a STEAL at $150. Everything I read pretty much mirrored what the posts are saying above—“great saw” , “a classic”, etc. etc. I was so excited about it that I quickly sold my Ridgid BS140002 since it was “junk made in China”. The Ridgid did need to be modified slightly but it was a great saw after I had it setup properly.
I purchased the saw for $150 but I’ve since spent countless hours on it and nearly $300 in bearings, tires, cool blocks, link belt, pulley, etc. etc. and now have almost $450 invested. The machine still shakes like hell and I’m considering replacing the stock 1/2HP Leeson Motor for a 1hp Grizzly in hopes it’ll solve the vibration issue. If it doesn’t I’ll have to remake a new base for it.
Moral of the story is I’m about ot have $600 invested in a 30+ year old saw that functions worse than my ‘cheap Ridgid’ that it replaced. I should have just ponied up the cash, saved myself the headache and purchased a Grizzly 14”. Keep that in mind when you go to see the saw. If it doesn’t function as well as you’re expecting it should, pass on it.
10401 posts in 3648 days
#7 posted 09-20-2014 07:57 PM
I see them for $100 or $150 now and again, but often
for a lot more and $200 is not a bad price at all if
it’s in working condition.
skogie1
#8 posted 09-20-2014 08:54 PM
Thanks for all the advice. I have to drive 2 hours to see it so I’m thinking now of purchasing a Steel City (either granite or cast iron, haven’t decided). There’s a big price difference because the Steel City is new, but I can save the drive and have a new machine.
View MrUnix's profile
MrUnix
6715 posts in 2199 days
#9 posted 09-21-2014 12:30 AM
I purchased a 28-200 several months ago for what I thought was a STEAL at $150. Everything I read pretty much mirrored what the posts are saying above—“great saw” , “a classic”, etc. etc. [...]
I purchased the saw for $150 but I ve since spent countless hours on it and nearly $300 in bearings, tires, cool blocks, link belt, pulley, etc. etc. and now have almost $450 invested.
It is a great saw, and what most all other 14” clones are copied from. I have the same saw (28-207) which is pretty much the same, but on a flare leg open stand. Picked it up along with a Boice Crane 6” jointer for $170. Both were in rough shape and the Delta didn’t even run. Did a complete restore on it.. stripped to bare metal, new paint, fixed the motor, new bearings, new tires, new kevlar belt, new wiring, new blade and I also had to obtain a few missing bits. Even with all of that, if you split the inital cost ($85 for each machine), I have a total of under $250 invested in the saw. What I wound up with was a machine that was in better than new condition, easily passed the dime test (better than the nickel test!) and an absolute joy to use. How you could spend $300 on just getting it running (not a restore) is beyond me!
PS: I restored the jointer and sold it on CL for $400, which basically paid for all that I had spent on purchasing and restoring both machines.
nicksmurf111
#10 posted 09-21-2014 12:44 AM
I’ve got the older version of the saw. I paid $250 for it, mainly because it came with the cast art deco base. I put a $25 motor on it, cord and light switch, upper bearings, and a quick crank…none of which cost very much. I still need to change the lower blocks. I admit, mine doesn’t run super smooth, but will hold it’s value. I can pick up a used import saw for $100 almost any day.
-- Nicholas
