acrylic
« back to Woodturning forum
Forum topic by ThEpEnMaKeR posted 09-19-2014 03:54 AM 801 views 0 times favorited 2 replies Add to Favorites Watch
View ThEpEnMaKeR's profile
ThEpEnMaKeR
19 posts in 1218 days
09-19-2014 03:54 AM
Topic tags/keywords: tip trick lathe turning modern
i have been turning wood for quite a few years now, but within the last year i have seen a lot of people working with acrylic on the lathe. so i ordered a few bottle stopper kits along with some acrylic blanks. the kits i ordered thread into the blank so instead of buying a tap the right size and messing around with that. i ordered the threaded inserts that p.s.i. just recently listed on their site. any recommendations on the type of glue i should use on the inserts. i normally use ca for wood. and any tips for working with acrylic are also appreciated
-- kazwoodturning.com
2 replies so far
View Sawdustmaker115's profile
Sawdustmaker115
306 posts in 1592 days
#1 posted 09-19-2014 04:22 AM
I would use a 2-part epoxy, I don’t have any experience with what your explaining but I know that epoxy works cause that is what I use to glue my pen tubes into the acrylic blanks with. Somethings I have found while using acrylic are:
Make sure your tools are sharp, acrylic dulls my chisels much, much faster then with wood. Just sharpen your tools often.
Don’t try to hog of a bunch of materiel at once, doing this tends to just make the acrylic shatter or cause ’’tearout’’ (I don’t know what else to call it… lol)
Go a bit faster, I have found for me turning up the speed of the lathe helps to reused the blank from catching
Now I am no expert, but these are just somethings I have learned over the time I’ve been working with acrylic pens. Hope that helps a bit. :-)
-- Anthony--http://knottywoodshop.weebly.com/
ThEpEnMaKeR
#2 posted 09-19-2014 08:25 AM
thanks for the advice. the parts i ordered should be in sometime next week. I’ll definitely put some pictures in my projects ad let ya know how it all worked out. dull tools will not be a problem i like to keep a stone on my lathe just to touch up my tools while I’m working
