barnwood
Forum topic by jnldr posted 294 days ago 484 views 0 times favorited 10 replies Add to Favorites Watch
View jnldr's profile
jnldr
2 posts in 294 days
294 days ago
I have many feet of barnwood that is laying around. It is actually off an old house I am in the process of redoing. I am wandering what to do with it all. Woodworking is something I know NOTHING about. My question is this. I think I can rework some of the wood and reuse it on the siding,but if I can not I was wandering what to do with it all short of burning it. If I can use it again i would like it to be cleane.
So my questionis this:
What can i do to clean it up?
Sand with like a belt sander?
Pressure wash it?
Chemicals?
Get a planer and run it through.
I was thinking a planer would bring it back to condition but I am not sure.
If I can not use it on the house I can at least use it to build cabinets and such in the house,is a planer what I need?
Thanks,
JNLDR
dennis mitchell
3790 posts in 1210 days
294 days ago
Planer will work watch for nails! What type of wood is it? What do you want it to look like? Is it brown or grey? Pressure washing might be just the thing if you like a rustic look. If you want a new looking wood you might see if you can sell it and just get new wood.
jnldr
2 posts in 294 days
294 days ago
I think it is poplar. I like the rustic look,it is grey. Is the planer,basically a sander and if so it will smooth it out correct?
dennis mitchell
294 days ago
It will cut the wood thinner and you will lose the rustic look. You might try a rough sanding with a belt sander and see if you like it.
View Primitiques's profile
Primitiques
24 posts in 312 days
294 days ago
how wide is it, i’ll buy it from you, thanks, bill
www.primitiques.com
View drbob's profile
drbob
25 posts in 312 days
287 days ago
Advertise it for sale. I often see ads from people wanting to buy barn board. I have used it to make mirror and picture frames and they turned out great.
-- drbob at http://www.Woodworkingtipsandtools.com
View Chris Wright's profile (online now)
Chris Wright
360 posts in 377 days
264 days ago
A pressure washer would take off any git and grime, cleaning the wood without loosing much in the way of thickness plus it will keep it’s rough texture. Just be careful though, if the wood is to soft a pressure washer will cut through it like it’s butter.
-- "At its best, life is completely unpredictable." - Christopher Walken
View willy3486's profile
willy3486
39 posts in 293 days
262 days ago
Heres a few pointers on old barn lumber. I have tore down a lot of old buildings and even built a 30×55 shop from old buildings. If it has any paint on it be careful. Old paint before the 80s can have lead, that’s something you don’t want to breathe. In that case I would probably pass on using. That’s why I prefer barns. As far as cleaning a low power pressure washer as mentioned does good if you are careful. If you don’t have a pressure washer one way I have cleaned it in the past is to get a bucket of water and pour in some bleach. Maybe a cup full in a 5 gallon bucket.just lean the wood so the water runs off. It cleans the wood good. When I use any old lumber I check for nails and then run a metal detector over the wood. You would be suprised at how many times you can miss some metal. It sounds like it doesn’t have paint on it so just remember about paint for future reference.
View Julian's profile
Julian
698 posts in 421 days
262 days ago
I just saw an ad in craigslist for barnwood for sale at $3.50 a square foot. You might want to research your options completely before spending money on expensive shop tools. You will end up needing much more than just a planer or even a drum sander.
-- Julian, Park Forest, IL
View gizmodyne's profile
gizmodyne
1678 posts in 986 days
262 days ago
I keep a large stock of douglas fir, discards from my neighbors additions. The wood is all over 100 years.
It takes a long time to reclaim it.
1. Wire brush it.
2. Metal detector, pliers, hammer, screwdriver, whatever it takes to get it going.
3. Bandsaw into boards.
4. Surface, just like anything.
A blog entry here with pics.
http://lumberjocks.com/jocks/gizmodyne/blog/556
View buffalosean's profile
buffalosean
61 posts in 283 days
262 days ago
There is a place outside of rochester new york that deals with reclaimed barn boards. The refire the boards ina kiln. not as much as the inital drying, only enough to kill any bacteria and bugs. Now this sep is more important if it’s going to be used inside a house.
When the company I was with got these boards, they where being used for draw fronts on cabinets and for cathedral ceillings ….i know what your thinking…. “barn board on the ceillings?” it all looked really cool when said and done. the home owner wanted the inside of the house to “look” like a barn. it was pretty slick looking when all said and done.
the place is ousdie of rochester in wellsville, ny. its called Barn Shadow Enterprises. they have a website www.barnshadow.com. they might have information if you contact them.
depending on what kind of look your liking for is going to depend on how your going to treat it.
the place in wellsville charged over $9 a board foot for barn boards that were not resurfaced or cleaned, they were only refired in the kiln and cleaned of all metal. the customer wanted a rustic look….. sorry i don’t have any pics.
-- Sean Buffalo, New York
