New here, need help with a maloof joint!
Forum topic by SeattlesSmoothest posted 09-19-2014 01:19 AM 1178 views 0 times favorited 5 replies Add to Favorites Watch
View SeattlesSmoothest's profile
SeattlesSmoothest
2 posts in 1215 days
09-19-2014 01:19 AM
Topic tags/keywords: question joining
As the title says I am new, hello, and I need help learning this joint. I can’t figure it out at all
5 replies so far
View crank49's profile
crank49
4028 posts in 2840 days
#1 posted 09-19-2014 01:57 AM
A wedged thru tennon.
The extra width of the wedge prevents the joint from rotating, acts like a keyed shaft.
Also, note the grain orientation of the wedge prevents the ends from shearing off.
And, it looks damn good.
9752 posts in 3517 days
#2 posted 09-19-2014 02:39 AM
I don’t know Sam’s methods very well, but I think
that may be a wedged tenon, cut-off and then a
slot routed with a template and plugged with the
long-grain part, more or less just for looks.
I discovered recently that the better approach with
wedged tenons is to glue only one face of the
wedge so the other can gap a little seasonally.
In the case above as I envision it the actual
wedge is hidden and the part you see is a
decorative plug.
SeattlesSmoothest
#3 posted 09-20-2014 05:27 AM
Thank you, I am gonna be using it to fasten stool legs on a guitar stand/stool. The legs are going to show through to the top of the seat like a dowel and I want to use this for looks, can I make the wedge out of steel or no?
TheWoodenOyster
1311 posts in 1804 days
#4 posted 09-20-2014 11:51 AM
You can make it out of steel. You just need a way to trim it once you pound it in. You could probably do it with an angle grinder, but you may risk burning the wood a little bit around the steel. Nonetheless, I think you could do it out of steel.
-- The Wood Is Your Oyster
View robscastle's profile
robscastle
4704 posts in 2073 days
#5 posted 09-21-2014 10:07 AM
Dear SS
I had a look into the photo you have shown.
Its possible it not a wedged tenon as such.
It is no doubt its a round tenon, however I do not think the “wedge” is actually a wedge.
Rational being, if you were to spread a round tenon with a wedge it would become oval and there would no longer be the precise round image show in the post.
The wedge may in fact be a piece of material ftted acoss the joint to prevent the tenon turning.
The shape of the wedge may be a parallel rectangular shape or it could even a round dowel as there is an apperance of a radius at the bottom.
Where did you get the picture from ?
I may do an experimental joint just to see how it turns out.
As Loren reports the wedge could below the section shown and I also agree with crank49 it does look good
-- Regards Robert
