Articulating hollower modification
« back to Woodturning forum
Forum topic by Troy Cleckler posted 09-18-2014 11:57 PM 906 views 0 times favorited 1 reply Add to Favorites Watch
View Troy Cleckler 's profile
Troy Cleckler
385 posts in 1365 days
09-18-2014 11:57 PM
So after playing around with the hollower for a couple days, it seemed to be binding in one direction. Seems that the bolts in the riser tube was pushing the swivel bolt to an angle. I tried using wood shims and that didn’t seem to help either. I rethought it and this is what I ended up with. I cut the riser tube off plate, drilled hole, welded a bolt in and threaded a 1/2” drill chuck onto it. Now it’s level and made all the difference in the world, smooth as glass now. Got in the Sorby Turnmaster and installed it and I think I’m going to like it as well. AZ carbide has a short video of how to modify it to accept the 30degree round cutter so I’ve got one of those coming too.
Just thought I’d share this so it might help give others, who want to build one, options and ideas.
I do have the hole drilled for 1/2”rod for laser set up. I’ll be working on that next.
-- Troy. - Measure twice, cut once and fill the gaps....
1 reply so far
View Woodknack's profile
Woodknack
11601 posts in 2374 days
#1 posted 09-25-2014 02:31 AM
This would probably gain more traction in the woodturning forum.
