Will denatured alcohol remove laquer?
Forum topic by mporter posted 09-17-2014 09:37 PM 1361 views 0 times favorited 8 replies Add to Favorites Watch
View mporter's profile
mporter
253 posts in 2481 days
09-17-2014 09:37 PM
Laquer that is fully dry? Will a rub down with denatured alcohol remove it?
8 replies so far
View Bill White's profile (online now)
Bill White
4853 posts in 3863 days
#1 posted 09-17-2014 10:15 PM
Not likely. Acetone will, but be VERY careful ‘cause it can be explosive in a confined area.
Bill
-- bill@magraphics.us
View Dallas's profile
Dallas
3599 posts in 2390 days
#2 posted 09-17-2014 11:05 PM
http://www.hirshfields.com/contractors/contractors_lacq1.html
mporter
#3 posted 09-17-2014 11:28 PM
Let me be more clear. I DONT want to remove the lacquer. I am using denatured alcohol to remove something else on my projects. I want to make sure it’s not removing the lacquer too.
View NoThanks's profile
NoThanks
798 posts in 1432 days
#4 posted 09-17-2014 11:30 PM
It can surely change the sheen in that area, and/or possibly leave rag marks in the finish.
Why don’t you post what your trying to remove that is on the lacquer and you will probably get better answers for what to or not to use.
-- Because I'm gone, that's why!
View Finisherman's profile
Finisherman
227 posts in 1752 days
#5 posted 09-18-2014 01:49 AM
I’d be cautious about using denatured alcohol to cleaned a lacquered surface. Lacquer thinner often contains methanol, a primary constituent in denatured alcohol. The denatured alcohol may soften the lacquer, or change its sheen, even if it doesn’t remove the finish entirely. Bottom line? I’d opt for mineral spirits or naphtha as a cleaner, rather than denatured alcohol. They’re much safer.
mporter
#6 posted 09-18-2014 02:12 AM
Ok, thanks for you help.
View bigblockyeti's profile
bigblockyeti
4981 posts in 1624 days
#7 posted 09-18-2014 02:16 AM
What are you trying to remove? I’d go with what will tackle that and nothing more aggressive just to be sure you’re not over shooting to the point of removing the lacquer.
View OSU55's profile (online now)
OSU55
1515 posts in 1893 days
#8 posted 09-21-2014 01:27 AM
DNA will not dissolve cured solvent lacquer. It’s a good choice for something difficult to remove. Do not use acetone though.
