laminated maple bench top
Forum topic by bdresch posted 09-17-2014 05:07 PM 1118 views 0 times favorited 5 replies Add to Favorites Watch
View bdresch's profile
bdresch
143 posts in 1602 days
09-17-2014 05:07 PM
I am tossing around the idea of building a roubo style bench and trying my best to save money. I have about 100 square feet of 3 1/2” wide by 3/4” thick tonge and groove maple flooring. I was thinking of cutting the tongue off and laminating a stack of them together to make a 3” thick top. Does anyone think I will have trouble making a top from material this thin? Every bench i have seen seems to use 6/4 or bigger boards. Also, the bottom faces of the hardwood has 2 wide grooves. Do you think I will have a problem glueing it up with those grooves?
Thanks,
5 replies so far
TheWoodenOyster
1313 posts in 1929 days
#1 posted 09-17-2014 09:00 PM
I bet you’ll be fine. I don’t think the board thickness is an issue. If anything, it’ll probably be more stable. Lots of glue and work, but I bet it will work. The one hitch may be the “2 wide grooves”. How wide are these grooves? You could always plane them off and end up with 5/8” or 1/2” planks, depending on how deep the grooves are.
Also, take any finish off before you glue up. I’d just plane it off or sand it off if you don’t have a planer.
-- The Wood Is Your Oyster
View JL7's profile
JL7
8660 posts in 2959 days
#2 posted 09-17-2014 09:37 PM
Go for it! I have built a few of these type things using flooring material….Like Oyster said, I would probably plane the grooves off (or mostly off). You might want to glue up in 3 or so sections and plane them flat and then do the final glueup…..good luck!
-- Jeff .... Minnesota, USA
View Bill White's profile
Bill White
4928 posts in 3954 days
#3 posted 09-17-2014 10:13 PM
Ideally, you could build up the top, then take it to a shop with a wide belt sander to have it well surfaced.
I see no probs with the 3/4” material.
Bill
-- bill@magraphics.us
bdresch
#4 posted 09-18-2014 12:13 AM
I just picked up my first planer today. A used Ridgid TP1300 for $150. My tentative plan is to make a split style so I can make 2×11” wide planks. I was hoping I could get by without planing off the grooves, but I think I will just to be safe. Thanks and I will be sure to post pictures when start.
View bondogaposis's profile (online now)
bondogaposis
4718 posts in 2345 days
#5 posted 09-18-2014 12:43 AM
If you have the time it shouldn’t be an issue. It will take a lot more time on the glue ups but the finished product should be the same as any other glued up panel.
-- Bondo Gaposis
