red cedar
Forum topic by FancyShoes posted 09-17-2014 01:22 AM 984 views 1 time favorited 9 replies Add to Favorites Watch
View FancyShoes's profile
FancyShoes
550 posts in 1266 days
09-17-2014 01:22 AM
Is it difficult to come accross 20ft long pieces of red cedar?
I may need some to finish the canoe I am wanting to start soon.
also if you guys know what kind of pricing I should expect.
thanks
I paid $8 for the canoe and all the strips on the ground at a auction last year. I had been wanting to build one for the past few years and found a great deal. Im taking all the old strips off, and start over since there is a lot of damage on the old pieces.
9 replies so far
runswithscissors
2641 posts in 1927 days
#1 posted 09-17-2014 06:43 AM
If you can’t find 20 foot cedar (not easy nowadays), you can scarf pieces end to end. Use at least an 8:1 bevel ratio. Scatter the joints when you put the “planks” on the hull.
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2271 days
#2 posted 09-17-2014 12:49 PM
A few years back I bought some ERC, and my hardwood place had lengths up to 16ft. You may be able to talk to them and see if there’s any way they can get longer pieces in.
View ChefHDAN's profile
ChefHDAN
1010 posts in 2751 days
#3 posted 09-17-2014 12:58 PM
My sawyer often resizes RC timbers and gets some very long stock from that process, since it’s usually pretty thin he calls me and sells it a .50bf because he knows I go through it frequently for cooking salmon. Scarf joint was already mentioned & I wonder if you could use a finger joint bit to glue up the lengths you need.
View timbertailor's profile
timbertailor
1594 posts in 1326 days
#4 posted 09-17-2014 01:53 PM
Some people love a challenge. I wish you luck and I am favoriting so I can see the outcome. It should be a real challenge and I wish you the best.
View sras's profile
sras
4741 posts in 3031 days
#5 posted 09-17-2014 02:41 PM
Your best bet would be a specialty shop that sells architectural cedar (think big beams in a church). Get ready to spend money…
On the other hand the scarf joint is a great solution. The finger joint is not likely to hold up to the twists and bends the strips go through when they go on the forms.
View shipwright's profile
shipwright
7893 posts in 2700 days
#6 posted 09-17-2014 03:26 PM
8:1 scarf as mentioned above will give continuous strength, just like a long piece.
On another note, good call on removing the old planking. I’m guessing that this project was aborted because it was becoming difficult to plank. The last picture looks all wrong.
Make very sure that the molds are all plumb, square and fair before you jump in and start replanking.
View ajthomas5009's profile
ajthomas5009
296 posts in 1519 days
#7 posted 09-22-2014 02:04 AM
I’m not sure if your looking for ERC (aromatic) or WRC but Cedar USA in Indiana has anything you could imagine when it comes to ERC. I believe shipping is 50-80$ for a decent sized order.
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
17517 posts in 1758 days
#8 posted 09-22-2014 02:15 AM
I’m assuming you’re looking for western red cedar or possible Atlantic white cedar. I know that the local lumber yard that supplied my red cedar deck lumber would at least be able to order some 20’. 16’ is very common. 20’ will probably cost $40-$50.
View HerbC's profile
HerbC
1721 posts in 2761 days
#9 posted 09-22-2014 12:10 PM
+1 on Cedar USA.
Richard (the owner, who goes by Cedarman on another forum…) is a great guy and if they can’t help you, nobody can.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
