« back to LumberJocks.com Site Feedback forum
| Forum topic by Primitiques | posted 293 days ago | 729 views | 0 times favorited | 9 replies | ![]() |
293 days ago |
293 days ago |
Why not use Pine??? -- Thos. Angle |
293 days ago |
Not sure how you could get OSB to look like Pine??? OSB is wafer board. Used mostly for sub-floor and wall/roof sheathing. You can buy tongue and grove lumber but you may have to special order it at a big box store. Ask at the contractors counter. -- DaveH - Boise, Idaho - “How hard can it be? It's only wood!” |
293 days ago |
I probably will use easter white knotty pine (.59 sq/ft), but looking for something that I KNOW will never crack/split. Any pointers????? thanks, bill |
293 days ago |
thanks |
293 days ago |
Plywood wainscot or pine wainscot boards. |
293 days ago |
There’s NO way to know if your wood will ever crack or split, when working with pine, or any wood for that matter. But when working with knotty pine, you’ll almost always get splits and cracks. -- Respect your shop tools and they will respect you - Ric |
293 days ago |
If it’s sealed good it shouldn’t split. |
159 days ago |
what should you seal it with? |
149 days ago |
I’d use waterbased polyeurathane, mop on 4 coats and sand w/250 grit b/n coats.You can use regular poly but when it gets scratched up you ahve to sand it down to the floor to make it look good, waterbased, you just sand with 250 and mop some more on. Its fun!! |
| Forum | Topics |
Woodworking Skill Share
2911 |
3934 |
256 |
947 |
223 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2377 |
522 |
