Have some Holly need drying answers
Forum topic by bowedcurly posted 09-16-2014 09:47 AM 940 views 0 times favorited 7 replies Add to Favorites Watch
View bowedcurly's profile
bowedcurly
519 posts in 1725 days
09-16-2014 09:47 AM
hello I have some 5ft holly logs 1 is 16” across and smaller what is the best way to dry without milling and kiln drying, thinking about just sealing the ends with paint and setting up in the barn loft.
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
7 replies so far
View bondogaposis's profile
bondogaposis
4723 posts in 2347 days
#1 posted 09-16-2014 12:51 PM
It will likely check if you don’t mill it.
-- Bondo Gaposis
View Grandpa's profile
Grandpa
3259 posts in 2671 days
#2 posted 09-16-2014 02:49 PM
I agree with Bondo. Mill it then paint the ends and you will have better luck.
View Nomad62's profile
Nomad62
726 posts in 2954 days
#3 posted 09-16-2014 05:23 PM
Holly is ridiculously difficult to dry without it warping into oblivion. While agreeing with the above statements, I’d add to cut the pieces thick to leave room for milling.
bowedcurly
#4 posted 09-17-2014 01:13 AM
thanks guys I will just paint the ends and chuck it in the loft, have 14 stitches in my leg from falling over or ran over by wheelbarrow, I really can’t do antthing right now, but thanks a bunch for the comments.
View Dark_Lightning's profile
Dark_Lightning
3159 posts in 3105 days
#5 posted 09-17-2014 02:50 AM
What is holly called here in the US? I like the white color and would use it in a project, but I don’t see it sold where I buy wood (pretty much Rockler, for my boutique wood).
-- Random Orbital Nailer
View summerfi's profile
summerfi
3921 posts in 1683 days
#6 posted 09-17-2014 02:55 AM
Using paint on the ends will not help much as far as checking and splitting goes. Get some paraffin canning wax and paint that on the ends. The results will be much better.
-- Bob, Missoula, MT -- Rocky Mountain Saw Works http://www.rmsaws.com/p/about-us.html
View WDHLT15's profile
WDHLT15
1741 posts in 2472 days
#7 posted 09-17-2014 03:02 AM
If you do not cut holly into boards and immediately after felling and put it in a kiln to control the humidity and the drying, it will gray stain on you in a very short amount of time and ruin it for that bright white color. There is no way around that, unfortunately.
