Issues with Grizzly Jointer fence sitting below outfeed table.
Forum topic by garlandkr posted 09-16-2014 12:20 AM 872 views 0 times favorited 3 replies Add to Favorites Watch
View garlandkr's profile
57 posts in 1436 days
09-16-2014 12:20 AM
I have a Grizzly Jointer, model G0656P, and after adjusting the outfeed table to be level with the blades now the fence is not high enough to move over the table. How can I raise the fence and maintain 90 degrees perpendicular to the table?
3 replies so far
View dlgWoodWork's profile
160 posts in 3686 days
#1 posted 09-16-2014 12:38 AM
First, I would think you need to adjust the blades to match the outfeed table, not the other way around. How much higher is the outfeed table than the fence? On my old 6” Grizzly jointer there were two small “nubs” on the bottom of the fence that actually slid along the table. Does yours have this?
If it is very close you may be able to loosen the fence and slightly lift the fence up onto the table. Some pics might help diagnose the issue too.
-- Check out my projects and videos
View MrUnix's profile
6480 posts in 2131 days
#2 posted 09-16-2014 12:51 AM
For machines with adjustable infeed and outfeed tables, you typically raise the infeed table to zero cut on the indicator, then you adjust the outfeed table to the same height and lock it in place. After that, you lower the infeed table to get it out of the way and set the knives to the height of the outfeed table. From your description, you either had your knives set too high to start with, or your outfeed table.. or both.
#3 posted 09-16-2014 12:57 AM
Thanks guys, looks like I was just doing it wrong. First jointer.
- Ken
