Delta 46-460 runs well, but all chucks have too much runout
« back to Woodturning forum
Forum topic by Pault28 posted 09-14-2014 05:36 AM 1572 views 0 times favorited 22 replies Add to Favorites Watch
View Pault28's profile
Pault28
21 posts in 2056 days
09-14-2014 05:36 AM
Hello all,
I’m new to turning and just bought a used delta 46-460. The lathe runs well and the spindle doesn’t seem bent and seems to run true. However, whenever I mount something ON the spindle, excessive runout is noticed. I’ve attached videos of the spindle with nothing in or on it, a live center mounted in it, a psi chuck, and a pen drilling chuck mounted.
I can’t think this is normal. Does anyone else have this problem or know of a remedy to fix this? Thanks I advance!
Spindle alone:
http://youtu.be/5LWuDbPR52U
Live center:
http://youtu.be/KW5aHMvx5Q4
PSI Economy chuck:
http://youtu.be/--vxVouPJxE
Dedicated pen drilling chuck:
http://youtu.be/LuzhViTStwA
22 replies so far
View Dutchy's profile
Dutchy
3035 posts in 2252 days
#1 posted 09-14-2014 06:56 AM
Hello,
At youtube
Live center:
PSI Economy chuck:
I got the messege this video is privat.
-- https://dutchypatterns.com/
Pault28
#2 posted 09-14-2014 07:02 AM
Oops. I fixed them.
Dutchy
#3 posted 09-14-2014 12:58 PM
When I,m looking to the video my first tought is that the flange has an incorrect allignment. this alligment has to be less then 0,01 mm. I couln,t find a picture of a lathe and therefore below a pictuture of a saw alligment. You need a dial indecator for measuring.
Pault28
#4 posted 09-14-2014 04:14 PM
The spindle seems to run true. I tried showing it in this video but I’m not sure how easy it is to see.
It seems like all is well until a chuck is threaded on.
View Nubsnstubs's profile
Nubsnstubs
1330 posts in 1813 days
#5 posted 09-14-2014 04:33 PM
Paul, to me it lookked live the live center was running true. You runout is in the chuck and the pen drilling chuck. Possibly the spindle adapters.
Also, if you want to show if the spindle is not true, show it from the inside of the taper. That is where the accuracy is supposed to be, not the threads, even though they are supposed to be. .......... Jerry (in Tucson)
Pault28
#6 posted 09-14-2014 04:38 PM
Here’s a video of runout inside the taper. Pretty good if you ask me.
http://youtu.be/P3w3W-wikIY
Here’s a video of the runout at the spindle base. Still seems within tolerance.
http://youtu.be/HRqWcpUhQJw
Here’s a video of the alignment of the drive spur and the live center.
http://youtu.be/3eDovdqFm24
And finally a video of the alignment while running. Not bad I think.
http://youtu.be/o_GfWbLI2Ec
Pault28
#7 posted 09-14-2014 05:53 PM
I think this may be a solution for me. Maybe my chucks are bottoming out on the last few threads of the spindle and not quite true. If I put one of these washers on before the chuck I wonder if the buck would tighten down against it well.
http://www.woodenpost.com/products/headstock_spindle_washers.htm
Has anyone used these washers before?
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3668 days
#8 posted 09-14-2014 06:41 PM
watch out for any dirt chjips under the chuck.Alistair
Dutchy
#9 posted 09-14-2014 07:45 PM
Hello Pault,
Look again to your video of the runout at the spindle base.
There where the hole is in your spindle you can see that the dial indicator is showing you a runout of almost 0,03.
Look at the point where the hole is in the spindle (to lock your spindle) base, and look again at your dial indecator. It is a very short moment at a very smal part, but even a small bump can cause your problem. Often this locking hole is deformd I,m almost shure this is the reason of your problem.
When your spindle is running in the third video (http://youtu.be/3eDovdqFm24) you can control the swinging. This swinging has to be less then 0,02 mm. Swinging is less inportant than the spindle base.
The fourt video is ( I,m sorry) privat
When y
Pault28
#10 posted 09-14-2014 08:08 PM
I fixed the last video. Sorry about that!
Thanks for all the suggestions. I did look at the spindle by the hole and there was the slightest bit of rust/grime that was causing the runout there. By the way, that is a hole for the knockout bar to sit I. If you’re trying to hold the spindle still while installing or removing chucks. I cleaned it up and the chucks are still not running true. It has to be either crappy chucks or something with the threads on the spindle since we’ve determined that the spindle itself seems to be running true.
How tight are the tolerances on the threads? That website I linked to seemed like it may be the solution for my problem. Having the washer may take up some of the slop in the threads perhaps?
Dutchy
#11 posted 09-15-2014 06:40 AM
Thank you Pault for fixing the fourtht video. That is what I ment saying: when your spindle is running.
I don,t think the washer will solve your problem, but give it a try For now I don,t know what the problem can be. Please let us know when you,ll find the solution.
Success, and I hope you can find it.
Pault28
#12 posted 09-17-2014 12:13 PM
So I’m feeling like a putz, but I completely forgot to try out the delta faceplate that actually came with the lathe. I threaded it on the chuck and it runs perfectly. It proved to me that the threads and spindle are good. I threw the PSI chuck back on and put a flashlight behind the lathe and I can see light peeking through between the base of the chuck and the shoulder of the spindle. I just don’t think the threads in the chuck enable the PSI chuck to butt against the faceplate. I threw the PSI chuck on the PSI adapter which adapts it down to the 3/4” thread for the old craftsman lathe and it runs just fine. I ordered a pair of the spindle washers. Hopefully they will make up the space on my delta and let the PSI chuck sit flat against the spindle. Looks like all is good. Should have the washers on Friday. Looking forward to turning.
Nubsnstubs
#13 posted 09-17-2014 04:31 PM
I don’t know if that lathe you have has reverse, but if it does, it might not be a good idea to use the washers in reverse if you don’t have set screws to lock the chuck onto the late… Jerry (n Tucson)
Pault28
#14 posted 09-17-2014 04:53 PM
That’s a very good point. I would only be sanding in reverse, so in that case, the wobble is not as critical (in my opinion). That being said, I would not run it in reverse while sanding with the washer. I’d only use the washer if I am running it forward and turning with the tools.
Pault28
#15 posted 09-17-2014 04:55 PM
Oops, in my post #12….
Referring to the delta faceplate, I meant to say “I threaded it on the spindle”, not on the chuck.
