Need to design a 6' dining room bench
Forum topic by Minorhero posted 09-14-2014 03:26 AM 929 views 1 time favorited 5 replies Add to Favorites Watch
View Minorhero's profile
373 posts in 2539 days
09-14-2014 03:26 AM
I am making a 6 foot long dining room table bench out of cherry and some hard maple. The bench will feature 10/4 legs and 6/4 stock for everything else. The bench is 18” high and 16” wide. My concern is whether I could support 500 lbs of weight on this bench without it failing. If not, then whats the best way to preserve the design but make fixes to it?
Here is a link to the google sketchup model.
And here are some pictures of the bench.
Any thoughts?
5 replies so far
View bubbastinks's profile
20 posts in 1300 days
#1 posted 09-14-2014 03:42 AM
I would think so and would build it with confidence if it were me.
View pintodeluxe's profile
5595 posts in 2747 days
#2 posted 09-14-2014 04:32 AM
I have had good luck with my two rail bench, a design very much similar to yours.
My tops were 8/4 and finished at 1-1/2” thick. If you are worried about the seat boards sagging, just make the top rails a little wider. 6/4 thick x 3” wide rails should be quite stout.
View LiveEdge's profile
574 posts in 1554 days
#3 posted 09-14-2014 04:46 AM
Behold! The sagulator.
I made some guesses for you and it looked ok. You can put the numbers in yourself.
#4 posted 09-14-2014 12:17 PM
Excellent, any thoughts on whether I can glue the top right to the aprons and legs, or should I be worried about wood movement?
View Logan Windram's profile
Logan Windram
344 posts in 2396 days
#5 posted 09-14-2014 02:01 PM
Always think about wood movement. I’d be careful about gluing that top to that base, there is a lot of movement in that top… Also be careful how much expansion there will be in those ends between those 2 posts. I’d probably do some hefty tabs screwed to top that slot into the base, much like a table top. That would allow for movement but still secure the top down nicely.
Good luck, post some pics!
