does anybody have a sliding miter saw thats accurate
Forum topic by joez posted 09-13-2014 01:07 PM 2542 views 0 times favorited 36 replies Add to Favorites Watch
View joez's profile
joez
120 posts in 2902 days
09-13-2014 01:07 PM
Topic tags/keywords: cuts
does anybody have a sliding miter saw from a company that make makes very accurate cuts.
36 replies so far
View lateralus819's profile
lateralus819
2241 posts in 1889 days
#1 posted 09-13-2014 01:16 PM
I have a Dewalt and it cuts spot on every time. Just take the time to set it up. I had to loosen the gauge, and re do it all a few times. But it is spot on now.
View jacquesr's profile
jacquesr
342 posts in 1422 days
#2 posted 09-13-2014 01:29 PM
I while ago Fine Woodworking Magazine picked the Bosch’s CM12 as the best for furniture makers.
Now, it is not sliding… The best is probably again the big Bosch GCM12SD is your best bet….
117091 posts in 3576 days
#3 posted 09-13-2014 01:35 PM
These guys claim to be the most accurate ,also the most expensive .
https://www.festoolusa.com/power-tools/miter-saws/kapex-ks-120-sliding-compound-miter-saw-561287
View Nubsnstubs's profile
Nubsnstubs
1287 posts in 1729 days
#4 posted 09-13-2014 01:52 PM
I have a 12” Dewalt, and it’s always been accurate from day 1. Been 4 years now, and it’s been abused all that time. Never dropped, but cut stuff maybe I shouldn’t have….......... Jerry (in Tucson)
View longgone's profile
longgone
5688 posts in 3308 days
#5 posted 09-13-2014 03:21 PM
I have had the Festool Kapex that A1Jim mentioned for several years and although it was expensive (the sting of the initial purchase has long been healed) I feel it was worth every penny and I am extremely impressed with its accuracy and quality.
View AlaskaGuy's profile
AlaskaGuy
4136 posts in 2308 days
#6 posted 09-13-2014 04:52 PM
If you want supper accuracy, first get away from a slider. To many moving parts.
Go to something like Omega.
https://www.omgainc.com/productfamily_detail.php?cid=2&sub_id=0&pid=12
View bigblockyeti's profile
bigblockyeti
5120 posts in 1720 days
#7 posted 09-13-2014 05:49 PM
The OMGA makes the festool look like a bargain and if you want it to be portable you’ll have to trade your 1/2 ton truck for a 3/4 ton just to be able to haul it around!
View Clint Searl's profile
Clint Searl
1533 posts in 2360 days
#8 posted 09-13-2014 05:58 PM
Yes
View DRSWoody's profile
DRSWoody
65 posts in 1379 days
#9 posted 09-13-2014 06:41 PM
I have a permanently installed 10” Delta slider that is always accurate. I recheck it every month or 2. I have another 10” Delta mounted on a folding sawhorse to use for on site use.
-- R. Smith Central Iowa
10396 posts in 3647 days
#10 posted 09-13-2014 06:41 PM
All the brand name sliders are probably accurate enough
for cabinetmaking and trim carpentry… DeWalt, Makita,
Bosch. There’s a race to the bottom going on though
like with Hitachi’s new 8.5” sliding saw being an inferior
replacement for the 8.5” saw it is supposedly an
update of. All these companies have to build to
fit price points. Only Festool seems to be sparing
no expense. You might look into Mafell and Metabo.
I had a DeWalt 8.5” slider and found it very accurate.
DW712… they don’t sell it anymore for some reason.
It’s a nice tool.
View TheDane's profile
TheDane
5423 posts in 3662 days
#11 posted 09-13-2014 06:57 PM
I have a 12” Hitachi slider that has been dead-on since the day I got it. I recheck it before each use and have never had to do any tweaks.
View BorkBob's profile
BorkBob
127 posts in 2692 days
#12 posted 09-14-2014 04:02 PM
I use the DeWalt DW712 (8.5” slider) at very accurate. I do a lot of 60/30 rail and stile joints because of this saw.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
View wseand's profile
wseand
2796 posts in 3041 days
#13 posted 09-14-2014 07:13 PM
I had a problem with my miters on the DeWalt, but solved it with a better blade.. A lot of he new saws come with construction grade blades. You might look into getting a better blade. As well you may need to tune her up a bit. Damn things travel all the way from China, so give the poor saws a break.
View Brad-Scott's profile
Brad-Scott
11 posts in 1904 days
#14 posted 09-14-2014 09:02 PM
I believe all mitre saws can be made accurate. I have been using a 10” Lowe’s/Kobalt slider for years. I ripped a sacrificial strip of maple for an insert in the bed of the saw, removed any and all extraneous “features” bolted it to a homemade bench of MDF, 2X2 with 6X28 inch rif sawn oak boxes on either end to match the height of the saw bed. The box risers are 3 1/2 high, the back riser is 5 1/2 so now I can lay in any stock length and cut to size.
I do check blade square in both directions and always get square cuts with a 60 tooth finish blade. No fussing, I use a 6” Swanson construction grade stair triangle (also available @ Lowe’s 6 bucks). Truth be known, there is no blade guard to get in the way of the square; dangerous but there is also no one in this shop but me and I am acutely aware of all risks. Additionally no stock gets crosscut until AFTER it has been dressed minimum two sides even 2X gets planned/jointed; I build primarily in hard maple, walnut , qtr-sawn oak and alder any 2X would be utility stock.
Miters on a Slider: Again the construction grade Swanson does the trick every time. I verify with a scrap cut. A combination of the Wixey Digital and bevel gauge can also be used to dial in a perfect 45^.
-- Brad~Scott
View papadan's profile
papadan
3584 posts in 3368 days
#15 posted 09-14-2014 09:49 PM
After replacing original blade without even trying it, and fine tuning all functions, my 10” slider cuts perfect angles every time. Does not matter if I am framing a deck or a picture, my Harbor Freight is dead on accurate. $79 (second one due to my Son confiscating the first)
showing 1 through 15 of 36 replies
