Planing lumber with the router - how I do it
Forum topic by JeremyT21 posted 09-13-2014 04:37 AM 1256 views 0 times favorited 3 replies Add to Favorites Watch
View JeremyT21's profile
JeremyT21
60 posts in 1460 days
09-13-2014 04:37 AM
Hey Everyone,
Nothing too new here, but this is how I use my router to plane cutting boards and also rough sawn lumber. It’s a very simple jig that could be made as complicated as you wanted to, but I am the impatient type so this is how mine turned out. The mortising bit really speeds this process up and makes a nice smooth cut.
https://www.youtube.com/watch?v=H55zqx09P4w&feature=youtu.be
-- www.rockytoptimber.com
3 replies so far
View mahdee's profile
mahdee
3883 posts in 1762 days
#1 posted 09-13-2014 02:57 PM
Good job. The only thing that I can suggest is to make some thin wedges to insert on both sides of your work piece so the board doesn’t move.
-- earthartandfoods.com
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#2 posted 09-13-2014 03:27 PM
Thumbs up, good job.
JeremyT21
#3 posted 09-13-2014 03:34 PM
Good job. The only thing that I can suggest is to make some thin wedges to insert on both sides of your work piece so the board doesn t move.
- mrjinx007
Thanks. I do need to make some dedicated wedges. I usually just search around the shop for tiny cutoffs that work as wedges, but thats a pain. I also need to redo the piece my router is mounted to. I need to make it longer so I can mount blocks to the underside to prevent from accidentally coming to far one way. That would suck to have it fall off and gouge the workpiece.
