Installing built-in book case flush with wall
Forum topic by robc posted 09-12-2014 04:45 PM 909 views 1 time favorited 5 replies Add to Favorites Watch
View robc's profile
robc
22 posts in 3218 days
09-12-2014 04:45 PM
Topic tags/keywords: built in custom scribe bookcase question
I am building to large bookcase/built in. They will look like to separate pieces that flank a wbf and mantle. Looking for advice on the construction and getting it flush to wall. Should leave 1/2 inch of plywood off the back to then scribe to wall. They will be anchor to the wall. I would like it to be flat to the wall with out trim. Just looking for advice on how to handle this.
5 replies so far
View mahdee's profile
mahdee
4006 posts in 1941 days
#1 posted 09-12-2014 04:51 PM
PM reedwood. He is an expert at it.
-- earthartandfoods.com
View pmayer's profile
pmayer
1032 posts in 3239 days
#2 posted 09-12-2014 04:57 PM
Check the wall for plumb to see how much overhang you will need off the back of the cabinet, then build your overhang accordingly. 1/2” is probably adequate, but it might not be. As far as creating the actual overhang and installing, I have done this a couple different ways:
1. Do as you describe. Leave an overhang off the back and use that as your scribe. Cut a rabbet on the back of the plywood so that you only have to scribe 1/4” rather than the full thickness of the plywood. Cut to your scribe line with a good jig saw, and tune the fit with a hand plane (something you don’t mind planing plywood with).
or
2. Build your face frame with a 1/4” overhang (making it 1/4” wider than the bookcase) and after the cabinet is installed, use a piece of 1/4” plywood to cover the visible side, and scribe that to the wall. That allows you to use a lower grade of plywood that has only one good face. It also makes the process of tweaking the scribe fit much easier. After it fits perfectly just apply a bit of glue and use a few pin nails to tack it in place
View robc's profile
robc
#3 posted 09-12-2014 05:10 PM
It’s actually the back of the cabinet that I have to fit. Not the face frame.
View robc's profile
robc
#4 posted 09-12-2014 05:12 PM
I see what you’re say now. The pic I post is basically what it will look like. Just use 1/4 ply to scribe and cover up the side. That’s a good idea. Thank you.
pmayer
#5 posted 09-12-2014 05:21 PM
yep, exactly. I more commonly use approach #1, but #2 works great as well, particularly for larger cabinets that can be a bit unwieldy to work with.
