how hot is too hot for blo drying?
Forum topic by futzy posted 09-12-2014 03:08 PM 867 views 0 times favorited 8 replies Add to Favorites Watch
View futzy's profile
futzy
4 posts in 1259 days
09-12-2014 03:08 PM
Topic tags/keywords: blo
Hello all,
This is my first post on LJ. I’m am currently finishing a cigar box ukulele and I am starting with Boiled Linseed oil. I know BLO dries fairly quickly (1-3 days) and I know the temperature plays a role in dry time but how hot is too hot. I live in the California desert and it is around 100 degrees right now. Can I leave it outside to dry, and how long should it take to dry at 100 degrees?
8 replies so far
Gerald Thompson
874 posts in 2140 days
#1 posted 09-12-2014 04:34 PM
I don’t know about 100d but a lot would depend on humidity. I live in high humidity Fl. and it usually dries in two days. Don’t put it out in the sun!
-- Jerry
4879 posts in 2399 days
#2 posted 09-12-2014 05:42 PM
The curing is a reaction with oxygen, and most chemical reactions occur quicker with warmth. 100ยบ isn’t too hot, but what’s next? It would be dry enough to top coat with most finishes within a day or so…..but it still takes quite a while to fully cure. I agree with Jerry, don’t put it in the sun….
View Rick_M's profile
Rick_M
11112 posts in 2286 days
#3 posted 09-12-2014 06:09 PM
Wipe off the excess oil, top coat it with shellac and forget about it. Shellac doesn’t care about oil, doesn’t care if it’s wet or dry. One won’t affect the other.
-- http://thewoodknack.blogspot.com/
futzy
#4 posted 09-12-2014 06:56 PM
I originally wanted to do a 30/30/30 poly oil and mineral spirits but I only have easy access to a lowes right now and they only carry water based poly. I didn’t want a super glossy finish. I might just end up mixing the shellac with the Blo to dull it down.
Just s&g’swhat happens if I put it in the sun.
Oh and humidity is not a concern here
futzy
#5 posted 09-12-2014 06:58 PM
Here it is with a single coat or BLO
View Hammerthumb's profile
Hammerthumb
2819 posts in 1881 days
#6 posted 09-12-2014 07:25 PM
If you put it in the sun, it will start bleeding oil out of the wood pores. Rick is right, coat it with shellac. You can then put a water based poly over it if you want to.
-- Paul, Las Vegas
Rick_M
#7 posted 09-12-2014 07:48 PM
Looks good futzy. Is that headstock raised instead of lowered or is that an optical illusion?
futzy
#8 posted 09-12-2014 08:23 PM
Thanks, and it’s an optical illusion. The head and neck are one piece but the head portion had 1/4 in taken from the width then I added a strip to the back for shape and to accommodate the depth of the tuning pegs.
Here is a better pic
