Help with log split up, please
« back to Woodturning forum
Forum topic by Troy Cleckler posted 09-12-2014 11:01 AM 1597 views 0 times favorited 9 replies Add to Favorites Watch
View Troy Cleckler 's profile
Troy Cleckler
384 posts in 1246 days
09-12-2014 11:01 AM
I picked up this stump yesterday and was wandering how to split it up. Do I concentrate on getting the one best piece or do I go with getting the most pieces? This will be only the second time at getting a piece from a log, so I’m not real sure of what I’m doing. I don’t know what wood this is so I’m not sure if it’s even going to be interesting inside, but then again, we really don’t know what’s in the package until we start turning.
I am working on building an articulating hollow snake so is this piece a candidate for a hollow form?
Any advice would be appreciated.
-- Troy. - Measure twice, cut once and fill the gaps....
9 replies so far
View mahdee's profile
mahdee
3831 posts in 1643 days
#1 posted 09-12-2014 11:45 AM
It looks like a cedar. If you don’t have a chainsaw, use wedges to split it.
-- earthartandfoods.com
View Rick_M's profile
Rick_M
10835 posts in 2255 days
#2 posted 09-12-2014 04:50 PM
IMO I’ll think you’ll be lucky to get one good piece with all those checks in the end and branches (knots).
-- http://thewoodknack.blogspot.com/
View Wildwood's profile
Wildwood
2204 posts in 2010 days
#3 posted 09-12-2014 07:42 PM
Agree with Rick M! When you see end and side checking/cracking on the outside of a log good chance have internal checks too! Problem with internal checking you do not see they show as you turn. I would use that old rotting, moldy stump to split firewood until fell apart.
-- Bill
View DaddyZ's profile
DaddyZ
2475 posts in 2916 days
#4 posted 09-12-2014 07:53 PM
Just start splitting & working, if you find it doesn’t work what have you lost (an old rotten log)
If all works out good you might have a very spalted chunk of great wood
Good Luck
View Nubsnstubs's profile
Nubsnstubs
1223 posts in 1605 days
#5 posted 09-12-2014 08:13 PM
Now Guys, don’t be so mean to that piece of wood. It’s a treasure In MY Opinion. That’s the stuff I like to turn. Unknown, beat up, dried out and cracked. There’s treasure in that thar wood…
Troy, go to youtube, put in Chas Thornhill, and look for his video on the elm bowl he turned. He rough turned to 1” thick, then drilled a bunch of 3/8” holes crossing all the cracks in the bowl. Then he inserted dowels and a couple pieces of aluminum rod.
I liked what he did enough to give it a try. Instead of aluminum, I used copper rod as I have a bunch of it. I also used wood dowesl. Aside from a couple mistakes I made, I was pleased with the results. I’m looking forward to doing it again.
With the proper planning, all wood is usable. It’s just a matter of personal taste in what you are willing to work. Remember, if you do turn this wood, it was your decision to do so.. Just covering my butt here, folks.
Here is the one I did. I have a couple better pictures, but they aren’t reduced in size yet.
............ Jerry In Tucson)
Rick_M
#6 posted 09-13-2014 03:24 AM
Nice Jerry. I might try that with a cracked mulberry blank.
Wildwood
#7 posted 09-13-2014 11:04 AM
Beauty or treasure in the eye of the beholder!
Chas Thornhill
https://www.youtube.com/watch?v=NmgZG4xlFBw
That technique will not work on every rotten, cracked piece of wood. Where Chas all ready working with a roughed out bowl Troy not there yet. Some of dowels appear to be random and add no strength to the piece.
Until Troy splits that stump will never know how much wood has to turn a hollow form safely. He would be safer stabilizing whatever hunk of wood ends up with Silmar 41 Clear Polyester Casting Resin, vice dowels.
http://www.uscomposites.com/polyesters.html
People have tried to stabilize rotten & cracked wood with CA glue only to have it come apart while turning.
While clear epoxies like Epoxy 330 Water Clear and West Systems 105 epoxy and 207 clear hardener would be a safer & stronger choice though very expensive. Thus casting resins cost not so out of sight a better choice.
There is a learning curve and other equipment needed to stablizing wood. Looking at the stump photos would not waste my time or money.
-- Bill
View TheDane's profile
TheDane
5349 posts in 3538 days
#8 posted 09-13-2014 11:38 AM
+1 … IMHO, this piece is too far gone. With the rot, checks, and cracks, it would be an accident waiting to happen.
View mudflap4869's profile
mudflap4869
1551 posts in 1334 days
#9 posted 09-13-2014 11:38 AM
There could be a swan in that ugly duckling. There is only one way to find out. Wedges and a maul will split it along its natural lines, and that is where the beauty is found. Even if you end up with only half the stump left it will be a free treasure and great experience for you. When we come to the edge of light one of two thing will happen. As we step into the darkness, there will be something to stand on, or God will teach us to fly.
-- Still trying to master kindling making
