Router safety
Forum topic by BigAxe posted 09-11-2014 08:51 PM 1167 views 0 times favorited 10 replies Add to Favorites Watch
View BigAxe's profile
BigAxe
32 posts in 1694 days
09-11-2014 08:51 PM
Topic tags/keywords: question
I use a router frequently. The router is handheld, I don’t have a router table.
Does anyone use an apron made out of Kevlar or some such material to protect themselves from the router bit.
If so where can I buy one
John
10 replies so far
TheWoodenOyster
1317 posts in 1958 days
#1 posted 09-12-2014 01:26 AM
You can buy bulletproof vests at gun shows. Literally. That might not be a bad choice
-- The Wood Is Your Oyster
View timbertailor's profile
timbertailor
1594 posts in 1447 days
#2 posted 09-12-2014 01:49 AM
Any clothing\protection you acquired would only provide a false sense of security.
Router safety is all about taking your time, being aware of what the bit is doing, what it will do, depending on route direction, how the wood is going to respond, and a whole host of factors that just take a little planing and forethought before you throw that switch.
View TheFridge's profile
TheFridge
9606 posts in 1509 days
#3 posted 09-12-2014 02:03 AM
I wouldn’t want to wear a fabric strong enough to catch and twist in a router bit.
View lab7654's profile
lab7654
266 posts in 2270 days
#4 posted 09-12-2014 02:11 AM
Just follow the basic safety procedures and you’ll be fine. Kevlar is designed to dissipate impact, I don’t think it would hold up much better to a cutting edge than any fabric.
-- Tristin King -- When in doubt, sand it.
runswithscissors
2764 posts in 2048 days
#5 posted 09-12-2014 03:24 AM
Actually, kevlar is very resistant to edged tools. Try cutting some with sharp shears. Not so easy. But I like the idea of a leather apron better than kevlar or any fabric.
TheWoodenOyster
#6 posted 09-12-2014 02:31 PM
You could go with the steel plate method. That’ll stop a router bit
View bigblockyeti's profile
bigblockyeti
5137 posts in 1744 days
#7 posted 09-12-2014 02:41 PM
If you’re actually worried about the bit cutting through or winding up and twisting whatever you’ve wearing, leather would be a better option. Any fabric you might be wearing could get (very quickly) wound up in a router bit. Leather being thicker option wouldn’t be able to “wind” much around a bit before stalling the router or breaking the shank of the bit.
View Julian's profile
Julian
1346 posts in 2713 days
#8 posted 09-12-2014 02:46 PM
Why not just make a simple router table. Many options to choose from on this website and the internet.
-- Julian
View sawdust703's profile
sawdust703
270 posts in 1443 days
#9 posted 09-12-2014 03:06 PM
I use a router regularly, as well, & have for several years. As many here have. In a table, and hand use, & am YET to have a bit come loose, or “fly” out of the router. I don’t wear an apron, or anything over my shirt when I use my routers. At times, I am fairly close to the router & bit for vision reasons. If all the right precautions are taken, the right bits are used with the right collets, & the right bits used for the job at hand, I don’t see what you’re worried about. Yes, I suppose there is always a possibility the bit could come loose, but, you don’t need to tighten the collet nut to the point of strippin’ the threads. As long as it is tight, it WILL stay put! Shop safety is important, but somewhat overdone on some things, IMO. Every tool you use has it’s “dangers” shall we say, but, if you learn to use it, & pay attention to whats going on around you, you won’t have any problems. One thing I will mention, that has to do with shop safety, some wear ear protection, some don’t. I, for one, don’t. I listen to the machine I’m using. You can usually tell by the sounds of the tool when something is wrong. Just learn to use it safely, Don’t get in hurry with it, & learn to listen to it. You’ll get along fine. Work safe, enjoy your project.
-- Sawdust703
View Lumberpunk's profile
Lumberpunk
334 posts in 2360 days
#10 posted 09-12-2014 04:16 PM
I have kevlar pants for chainsawing, maybe there is a bib.
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
