I found a stanley no 220 at a flea market the other day. I know it isn't the most usefull block plane there is, but for 2$, I couldn't resist. Plus, I wanted for some time to test painting a plane and see what kind of results I can get (and decide if I go down that road for other planes that could use a little love).
So I cleaned it, repainted (no too bad) and took care of the blade. I almost like it. It's just that one thing; the knob is chipped.
It's the kind where the wood was threaded, so I'm not sure how I could manage to build a new one. Any suggestion?
I've had success with just making the hole smaller and force it on. Its a delicate line between to much force and it splits, and not enough force and it doesn't work.
Another option is buy a threader as Nick suggested.
and a third option is find a bolt close to the same size and make a threader. All you need to do Take a bolt or screw the same size and with a file (use a triangular file or the corner of a square file) cut a groove perpendicular to the threads. Use this for threading.
And the last option, find a broken 220, and use the theaded piece to make a threader as in the last option.
And another option, ping Terry he'll probably turn and thread one for you for next to nothing.
looking at the 220 knob threads I would try making a threader out of a 7/16" lag bolt as the threads are coarser than any standard bolt thread i.m.o.. the threaded post on my 220 mics at .413 which would be bigger than 3/8" yet smaller than 7/16" so filing the bolt down to match the post may just work.
Sam-
Not only a replacement knob from a #220…but I believe that a knob from a #110 or #120 would also fit as would knobs from a #203 and #140 (but why you'd want to pull knobs off the last two unless broken is beyond me).
Not all manufactures used the same threads on their knobs so be forewarned about switching among brands.
I have wondered if threads could be formed from epoxy? If a knob was turned and drilled to the "right" size and the post and surrounding neighborhood were masked off with saran wrap or wax could a blob of epoxy be put in the knob hole and then screwed onto the cast iron post?. Would the epoxy form threads inside the knob? Just wondering.
@Upstate; I thought about it but somehow the idea of spending 40+$ on a tool to fix a tool that costed 2$ bothers me
@Don; I'll probably try your trick of making the hole 1/32 smaller than the threads and force it into. Maybe that just adding a drop of hot glue would help it stays in place without damaging the plane body if I ever want to replace it later
@upchuck; the idea of epoxy isn't bad, but would probably be quite messy!
The thing with the vintage Stanley planes is that they were designed before standard screw sizes where around. I needed a tote screw on mine, and ended up buying one for a few dollars off Ebay.
If your not in love with this plane, and considering it stands you only $2, even though I can't stand saying this,
just file the groove into the top threads of the plane itself…
I have considered doing this myself but I never could push myself to actually do it…
But it is an effective no cost option…
Just be aware you may hate yourself afterwards…lol.
Edit…Just had a thought, make a new knob with a slightly tight hole and epoxy it,,,
@69BBNova; yeah I thought about epoxying a new knob. But I don't like doing stuff that is "permanent". Removing epoxy isn't fun, so I tend to avoid using it except for lamination.
But right now; I have a bigger problem; I realized that I need to find a way to turn the know. All the one that I did in the past was with my drill press where I use a bolt going through the whole wood block for turning. Now, I cannot do the same thing for this. So I'm thinking of either trying to build a lathe chuck for the drill press (not too sure how yet) or turn it as usual and plug the hole with a dowel (and pretend that it was part of the intended design… )
I've done that before. In my specific experience mine was not METRIC and they are not a standard Imperial size. They were an imperial measurement, but not our current standard. Have fun finding the correct tap.
My #5 tote screw was a #12-20. I'm not sure what the knob screw is on a 220. Now I want to take mine apart and see.
I was just recently given a decent lathe, (its was free and now its better)...
But before that I used my drill press a couple of times and once I had to do something where I could not use a thru-bolt…
I drilled a hole in the piece I wanted to use and glued a good size dowel in it…
After I shaped it I cut the dowel off then drilled the size hole I actually needed…
This is what happens when you think how you would build things while waiting over 40 years until you have the machines to actually do it…
The part your going to love is I spent the holidays last year in the hospital because I had a stroke…
What the Hell Ya Gonna Do…lol…the thing is I actually laugh when I think about it…
I couldn't really walk or use my right arm very much at all, then after a couple of hours dragging my self to the left to transfer myself without help I told the CNAs my right side was saying,
Wait For Me, Wait For Me…
The crazy part was it was the best holidays I have ever had in my entire life, a LOT of laughing.
I never new why I've always been that way.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
