magnetic knife rack
Forum topic by willhime posted 09-11-2014 06:29 AM 2309 views 1 time favorited 9 replies Add to Favorites Watch
View willhime's profile
willhime
107 posts in 1536 days
09-11-2014 06:29 AM
Topic tags/keywords: question tip trick
I’ve been losing the battle on getting this knife rack up to snuff over the past week. About $30 on rare earth magnets (supposedly the strongest readily available magnets there are), and the rack will just barely hold up a USMC Ka-bar knife. I used that knife as a model because the majority of households will usually have the big bulky german knives vs lighter japanese ones. Every tutorial I see online has the instructions to drill out or route out the back side leaving only 1/8” surface wood so the magnets can get as close as possible to the surface. After doing that so thin, I could see daylight through it when held up, the knife was still hanging on by a prayer. So next, I decided to surface mount all the magnets and put a piece of thin veneer (1/32”) over the ugly face to hide all the glue and of course magnets. I now have roughly 60 magnets on this 20” rack and it’s still not strong enough to my liking. Am I missing something? I have no idea what else to do…
-- Burn your fire for no witness
9 replies so far
View RRBOU's profile
RRBOU
176 posts in 2289 days
#1 posted 09-11-2014 09:42 AM
When it comes to magnets bigger is still more powerful. If you would have used larger diameter magnets you would have the results you are seeking.
-- If guns cause crime all of mine are defective Randy
View mtenterprises's profile
mtenterprises
933 posts in 2690 days
#2 posted 09-11-2014 11:00 AM
As I see from your picture how all your many magnets are mounted my question is. Are all the same poles facing in the same direction? You do know that one side of the magnet is north and the other south if they are mixed in which way they are facing the the strength is diminished. I know this from building a magnetic stud finder, all have to be facing the same way.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View ChefHDAN's profile
ChefHDAN
1062 posts in 2846 days
#3 posted 09-11-2014 12:30 PM
I was curious so I just went and tested it, the 1” RA magnet in my magnetic featherboards can lift a 10# balanced weight. If you look at the design of the traditional mag bar used for knives the magnet is sandwiched by steel to make contact with the blade. Your design doesn’t have enough magnet force, especially with the veneer separation. Also, and it may be a visual photo trick, but it looks like some of your magnets are recessed below the surface of the wood, and/or tilted a bit in their holes, that coupled with the polarity question may be your issue. To try and use your investment of magnet so far, I’d start over and run a dado with router or TS and line up the magnets in a tighter pattern so that they would have more contact with the blade.
willhime
#4 posted 09-11-2014 09:34 PM
salvaging the magnets would be preferable, but I don’t know if I can get them out (LocTite) without breaking them since they’re super brittle
View Richard's profile
Richard
1916 posts in 2687 days
#5 posted 09-11-2014 09:49 PM
I would think that the magnets you use did not have the strength you need for a knife rack. These guys have some that are small enough to work for it have over a 20 pound hold strength, even if the wood cut it down by half that wouold still be 10 pounds and that should be good enough for kitchen knives.
http://www.kjmagnetics.com/products.asp?cat=10
DC6-N52 29.7 lb $6.39 ea.
3/4” dia. x 3/8” thick
Nickel Plated
Axially Magnetized
DX04B-N52 33.7 lb $7.70 ea.
1” dia. x 1/4” thick
Black Nickel Plated
Axially Magnetized
View hairy's profile
hairy
2701 posts in 3529 days
#6 posted 09-11-2014 10:18 PM
I went the simple route. It’s a magnetic bar attached to the fridge. These are made for tool organizing. The ones I have came from one of the tool trucks, Mac, Matco, SnapOn, I don’t remember.
It’s a T shaped housing, the magnets on each side are exposed. Harbor Freight sells a less costly version.
http://www.harborfreight.com/18-in-magnetic-tool-holder-61199.html
I have some of the HF magnets for holding files and other tools. They aren’t as strong as the tool trucks, but much less money.They should definitely be strong enough for kitchen knives, I have some good sized files hanging on them. With some imagination, they could be embedded into a wood strip, that would look nice. Leave the magnets exposed.
-- My reality check bounced...
View wunderaa's profile
wunderaa
248 posts in 2199 days
#7 posted 09-12-2014 12:37 AM
Just a thought to get you through this one….don’t rely on your block to hold the knives with the handle downward. Reverse them with handle upward and call it a day. Just let the knife shoulders help you out. Next time use 3/4×1/8” rare earth magnets. You can space them out to every inch and a half and be good to go. I much prefer your veneer technique…easier and cleaner in the end.
View Manitario's profile
Manitario
2630 posts in 2880 days
#8 posted 09-12-2014 01:47 AM
The magnets you used are too small; I used 1” magnets from Lee Valley and have no problems holding up my large knives. As well, you can set the magnets in metal cups which further increase their strength. See this article from Lee Valley:
http://www.leevalley.com/en/wood/page.aspx?p=40077&cat=1,42363
runswithscissors
2751 posts in 2022 days
#9 posted 09-12-2014 03:27 AM
Could your knives be stainless? Though some stainless alloys do respond to a magnet, many do so weakly, or not at all.
