Best router and table to buy
Forum topic by Tom Godfrey posted 09-10-2014 04:31 PM 1823 views 0 times favorited 11 replies Add to Favorites Watch
View Tom Godfrey's profile
Tom Godfrey
488 posts in 2046 days
09-10-2014 04:31 PM
Topic tags/keywords: router reviews power tools making moulding making cabinet doors best router table
Now that I am having to replace some tools that were stolen i am wanting advice on the best router to use with a table? I realize there are a lot out there and some cheap and some not so cheap. I would like your opinion no matter the cost even if i couldn’t afford it.
My general use would be for cabinet doors, making moulding and things of that nature. Want a set up that want take hours to set up and make changes when needed.
Thanks in advance
Tom
-- Tom Godfrey Landrum South Carolina (tomhcww@gmail.com)
11 replies so far
View johnstoneb's profile
johnstoneb
2691 posts in 2043 days
#1 posted 09-10-2014 05:23 PM
Jess-em
-- Bruce, Boise, ID
View timbertailor's profile
timbertailor
1594 posts in 1294 days
#2 posted 09-10-2014 05:51 PM
If you want the best, then you might want to take a look at my router table workstation.
Took a while to gather all the pieces and assemble but I would have to say this is a great set up that I think anyone would be proud to own.
View retfr8flyr's profile
retfr8flyr
370 posts in 1539 days
#3 posted 09-10-2014 06:28 PM
I agree with the Incra setup but I have mine setup in my table saw. I have the PC 7518 for a router and the Incra Mast-R-Lift II with their Clean Sweep system. I love the setup it’s extremely accurate and very repeatable. I recently added a Wixey DRO and that makes it even better.
-- Earl
View Loren's profile
9760 posts in 3518 days
#4 posted 09-10-2014 06:53 PM
If you want to make doors consider a shaper.
View pintodeluxe's profile
pintodeluxe
5544 posts in 2684 days
#5 posted 09-10-2014 08:06 PM
I think you are on the right track looking for a router that is easy to setup. I like routers that have topside adjustments. Furthermore, the collet should extend above the table to make bit changes easy. I don’t like to mess with bent wrenches, I just want to lock the collet and change the bit with one wrench.
The Freud FT1700 meets all of these requirements for me. I have been told they no longer manufacture them, but if you can find one they are great.
Triton routers have similar features.
View ducky911's profile
ducky911
237 posts in 2660 days
#6 posted 09-11-2014 02:44 PM
you might want to wait for this
AWFS: Rockler Set to Release Computer-Controlled Router Table
http://www.finewoodworking.com/item/108443/awfs-rockler-set-to-release-computer-controlled-router-table
video
https://www.youtube.com/watch?v=tJxzRwUJfMo
View Jim Jakosh's profile
Jim Jakosh
19956 posts in 2976 days
#7 posted 09-11-2014 04:57 PM
I know they make power lift inserts now but when I bought mine it was manual and it is a Woodpecker Quick Lift and I love it. With one handle you can turn and lift the router up to change the bits and then place it right back down for cutting. I do not trust the readout so I made a drop indicator for accurate measuring the movement of the bit when making adjustments and I’d use it with any of the lifts. You can use just about any router in it. I have a Milwaukee in mine! Check the body size before you buy the router.
Jim
View RogerBean's profile
RogerBean
1605 posts in 2824 days
#8 posted 09-11-2014 05:14 PM
Tom,
I’m with Earl above. I use a shop made router cabinet with an Incra fence and a bosch 1 3/4 hp router, mounted in an Incra PRL-V2 lift. The precision is unmatched, and the convenience is great. I’ve tried several router table set-ups and find this one to be best of class. Whether mounted to the table saw or in a separate cabinet or table, these components make routing a pleasure. The Incra magnetic metal throat plates are a charm to use.
Truth is, you can do wonderful work with a piece of plywood and a clamp mounted fence. But it’s not as convenient, or quick, or as much fun. I’ve become a die-hard Incra fan.
Of course, if you want to do big, heavy work, a shaper is the tool of choice.
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
View UpstateNYdude's profile
UpstateNYdude
909 posts in 1853 days
#9 posted 09-11-2014 07:15 PM
I agree with the Incra setup but I have mine setup in my table saw. I have the PC 7518 for a router and the Incra Mast-R-Lift II with their Clean Sweep system. I love the setup it s extremely accurate and very repeatable. I recently added a Wixey DRO and that makes it even better.
- retfr8flyr
I just bought that exact same setup because of looking at yours but, I have a Milwaukee 5625 router and I’m in the process of attaching it to my 1023.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
retfr8flyr
#10 posted 09-11-2014 08:00 PM
- retfr8flyr
I just bought that exact same setup because of looking at yours but, I have a Milwaukee 5625 router and I m in the process of attaching it to my 1023.
- UpstateNYdude
I think you will love it. The Incra fence on the saw is fantastic and I can’t imagine going back to a regular style fence. I am very happy with this router setup, it’s just like having a separate router table. Did you get the Clean Sweep setup also?
-- Earl
UpstateNYdude
#11 posted 09-11-2014 08:46 PM
I got it all including the wonderfence, the Mast-R-Lift II, and the Cleansweep.
