How to create this profile
Forum topic by Notw posted 09-10-2014 02:59 PM 1201 views 0 times favorited 16 replies Add to Favorites Watch
View Notw's profile
Notw
681 posts in 1995 days
09-10-2014 02:59 PM
I coworker of mine has asked me to recreate his window surround because they are currently made of vinyl and his wife doesn’t like them and would prefer wood. Creating the basic oval and cutting it out weren’t a very big deal but now I am confused on how to create the profile that is on the surface. He says it doesn’t have to be exact but he would like it to be close. Thank you
16 replies so far
View Yonak's profile
Yonak
986 posts in 1763 days
#1 posted 09-10-2014 03:13 PM
The profile can be done using different sized cove bits in a router, mounted in a (temporary ?) table. Do it before cutting out the center of your piece.
Drill holes in your table (or temporary surface) the correct radius for each cut and insert a peg. Then drill a hole in the center of your piece to fit over the peg. Turn the piece around the peg to cut the profiles.
Be sure to hold the piece tightly to avoid chatter, otherwise sanding will be more difficult than it needs to be. It’s always good practice to practice first on a scrap piece until you’re sure you’ve got the procedure down.
It might be a good idea to use a scrap plywood disk between the piece and your hands, not only to protect your hands but to help hold the piece flat on the table and to give it more beef. If the two pieces tend to slip, try using a piece of rubber drawer liner material between them or screwing them together.
Be sure to wax the table surface. Don’t try to cut the entire depth at once. Take it slow but steady. If it tends to burn you may have to up your speed a bit. Good luck and have fun.
View Notw's profile
Notw
#2 posted 09-10-2014 03:37 PM
so if I have already cut out the center how would i do this?
View DonBoston's profile
DonBoston
81 posts in 1704 days
#3 posted 09-10-2014 03:58 PM
Multiple pegs on the inside of the circle.
-- Don Boston RECreations by Don http://recreationsbydon.com
Yonak
#4 posted 09-10-2014 06:15 PM
The back side will not be seen, I assume ? Tack it to backing piece(s), as mentioned above, and drill the center hole through the backing piece.
View bigblockyeti's profile
bigblockyeti
5324 posts in 1962 days
#5 posted 09-10-2014 06:29 PM
These are usually done with a moulding machine capable of making round and elliptical shapes. The Williams and Hussey machine comes to mind. While there may be other ways to do this, I have no experience in doing it any other way.
View Notw's profile
Notw
#6 posted 09-10-2014 06:33 PM
Wow bibblockyeti those are awesome machines, wish I could afford those
bigblockyeti
#7 posted 09-10-2014 08:23 PM
They’re pricey, and pretty limited in what they can do, but if you’re in that business one could be invaluable.
View REO's profile
REO
929 posts in 2316 days
#8 posted 09-10-2014 09:07 PM
faceplate on a lathe
View Notw's profile
Notw
#9 posted 09-11-2014 01:18 AM
REO i don’t have a lathe so i’m not sure what that means
View jerryminer's profile
jerryminer
944 posts in 1683 days
#10 posted 09-12-2014 06:24 AM
- Yonak
Trouble with this is—-he’s got an oval shape, not a circle. There is no “correct radius”. The lathe solution is problematic for the same reason.
You might be able to use two pegs like a fence in a router table—(or two bearing points attached to a fence)—the cut will vary some as the curve changes, but you should be able to “feather out” the difference with sandpaper, scrapers, ...
View jinkyjock's profile
jinkyjock
488 posts in 1816 days
#11 posted 09-12-2014 10:38 AM
Notw,
doesn’t look a very complex profile so have you thought of making a scratch stock.
There is a good video by Garret Hack (Fine Woodworking) on how to make one.
Cheers, Jinky (James).
View Sylvain's profile
Sylvain
769 posts in 2741 days
#12 posted 09-12-2014 03:39 PM
If you don’t use a scratch stock
(Search also on Paul Sellers blog and on “the village carpenter” blog for scratch stock)
You will find various electric router jig to make ellipses here on Lumberjock; some where the router moves others where the board moves under a fixed router.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
Yonak
#13 posted 09-12-2014 04:53 PM
- Yonak
Trouble with this is—-he s got an oval shape, not a circle. There is no “correct radius”. The lathe solution is problematic for the same reason.
- jerryminer
Sorry .. missed the part about it being an ellipse and not a circle.
View mahdee's profile
mahdee
4045 posts in 2009 days
#14 posted 09-12-2014 04:57 PM
Why not veneer over the vinyl one?
-- earthartandfoods.com
View LeTurbo's profile
LeTurbo
234 posts in 1827 days
#15 posted 09-12-2014 07:49 PM
I’m thinking jerryminer has the solution I’d most likely try, with the two pegs. Otherwise, I might try a single peg on the inside of the oval – the trick here would be to keep a relative perpendicularity (if there’s such a thing) with the cutter. Now, as to getting the actual profiles – sheesh, that could be a bother unless you have a mad selection of cutters. This is where Mattias Wandel’s tilting router table would probably be useful.
