NEW toCNC world
« back to CNC Woodworking forum
Forum topic by tully posted 09-10-2014 01:38 PM 1341 views 0 times favorited 15 replies Add to Favorites Watch
View tully's profile
tully
9 posts in 1351 days
09-10-2014 01:38 PM
I’m new to the CNC world ,mostly old school woodworking, but I have a question could I use it to make the slots in shutters?
<<<<<<<<<<< <louver groves????
Dennis
-- Dennis Gerard old yankee workshop
15 replies so far
View ChrisK's profile
ChrisK
1962 posts in 3077 days
#1 posted 09-10-2014 03:40 PM
One of the first things with a CNC that you need is way to visualize what you want to do and determine what needs to be done to the machine to get what you want.
Is you machine big enough to hold the piece to be cut?
What has to be done to hold the part to be cut and possibly index it?
Can you use the CNC to make a template and hand route instead?
-- Chris K
tully
#2 posted 09-10-2014 03:52 PM
thanks for the reply
pieces are 1.25” x 2” X 24”
pieces could be clamped or hold as there 3” space top and bottom
Hand routing is out as it would be 100’s of them
ChrisK
#3 posted 09-10-2014 03:58 PM
Lay out parts and write a test program. What CAD and CAM Software are you using?
Make sure you can index parts if they are too long to slot in one pass.
Make sure your clamps are out the way. you don not cutter or machine to hit them.
.i usually model in CAD and then write(generate) code from the CAD model.
-- Chris K
tully
#4 posted 09-10-2014 04:02 PM
have not bought a machine yet just starting to look…
ChrisK
#5 posted 09-10-2014 04:04 PM
Are all you doing is slotting for louvers?
-- Chris K
tully
#6 posted 09-10-2014 04:10 PM
yes
ChrisK
#7 posted 09-10-2014 04:21 PM
You might want to look at a more dedicated machine. A CNC router will be at least $4K for 24 X 36 machine bed. The software can be another $1K to $10K depending on what you want. A longer machine will allow for less indexing, you mentioned 100’s of pieces. Look for used machines or maybe contract with a local cabinet shop?
Look at setting up both sides in one fixture, maybe 2 or more sets to save set up time.
Though in the long run a CNC is versatile.
Good Luck, let me know what you find.
-- Chris K
tully
#8 posted 09-10-2014 04:27 PM
A good used louver machine is 5K and that’s all you can use ot for a CNC is the louver business does not pan out I can use it for other things
View brtech's profile
brtech
1029 posts in 2918 days
#9 posted 09-10-2014 06:42 PM
If you can do it with a router, you can do it with a CNC machine. How long it would take, and how expensive it would be depends on how many steps, and how expensive a machine you get.
View Ger21's profile
Ger21
1074 posts in 3127 days
#10 posted 09-11-2014 12:55 AM
tully
#11 posted 09-11-2014 01:07 AM
http://www.youtube.com/watch?v=RZNzWCsvMWY
This is what I need just not as deep as he’s doing it…
What type of a cnc would I need to do this only need 13 slots… in 24” board with space on the and bottom?
tully
#12 posted 09-11-2014 01:48 AM
ChrisK
#13 posted 09-11-2014 12:14 PM
tully,
Look around here:
http://www.cnczone.com/forums/general-full-3d-wood-router-machines/151142-jcut-6090a-review.html
The beefier the machine the faster you will be able to cut, up to the cutters limit. You will need to make sure the distance from the cutter to the table is big enough and that Z travel is long enough. It looks the jcut-6090a may be a little short there. Some machines it is a simple matter to raise the router gantry others are a lot harder.
The Z travel is perpendicular to the table. Machines designed for engraving will most likely not have a lot of Z travel.
http://www.camaster.com/
or build your own: http://buildyourcnc.com/blacktoe.aspx
-- Chris K
Ger21
#14 posted 09-12-2014 02:17 PM
From what I’ve heard, those Chinese machines on Ebay are mechanically decent, but often have garbage electronics that may need replacing. By replacing electonics, you can greatly increase the performance, and it’s still a very good price.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View JAAune's profile
JAAune
1798 posts in 2313 days
#15 posted 09-12-2014 03:23 PM
The controller software that runs the machine is also important. Make sure you know what software is required, how much it costs and what CAD programs will output the correct G-code to the controller.
