How to cut clean recessed screw holes?
Forum topic by Vaul posted 09-10-2014 01:02 AM 5198 views 0 times favorited 22 replies Add to Favorites Watch
View Vaul's profile
Vaul
22 posts in 1263 days
09-10-2014 01:02 AM
Topic tags/keywords: recessed screw tear out skill question
Hi all,
I’m new to woodworking so forgive the beginner question. I’d like to know how to make clean recessed holes without a drill press?
I’m making tool mounts for my shop, and some of them will be mounted with recessed screws, which I may later cap. So far I haven’t been able to keep the recessed holes clean. They either have chipping out of the top grain or the bit wanders and makes a rather ugly, non-circular entry hole.
I do not yet have a drill press, so I’m doing this with my cordless drill.
I’ve tried drilling smaller guide holes first, with no luck.
The bits I have are all metal cutting bits, so is that likely the main problem?
Most of the holes I’m cutting are 1/4” or 3/8”, just large enough for the screw heads.
I have tried searching on this, but all the info I got was on avoiding tear out on the bottom, which isn’t my issue.
Thanks!
Jon
-- Jon (aka. Vaul)
22 replies so far
View Loren's profile
9948 posts in 3553 days
#1 posted 09-10-2014 01:11 AM
Regular drill bits are ground to a shape for drilling
in metal. For wood the cleanest holes are drilled
by using scoring on the outside rim.
If I were in your shop I could show you how to
turn a regular twist drill into a “cabinetmaker drill”,
a sort of shop-made brad point. I use a standard
shop grinder wheel corner to freehand grind them
on bits down to about 1/4”. Here’s a video of a
guy making them in a more elaborate and precise
manner, but the idea is the same.
https://www.youtube.com/watch?v=OeT6HSPaTPc
View Ger21's profile
Ger21
1074 posts in 3036 days
#2 posted 09-10-2014 01:26 AM
View NoThanks's profile
NoThanks
798 posts in 1434 days
#3 posted 09-10-2014 01:36 AM
I use forstner bits when I need a clean hole.
-- Because I'm gone, that's why!
View timbertailor's profile
timbertailor
1594 posts in 1329 days
#4 posted 09-10-2014 01:37 AM
- Iwud4u
Ditto. Well worth the investment in a set.
View TheFridge's profile
TheFridge
8882 posts in 1391 days
#5 posted 09-10-2014 01:44 AM
Forstner. I use the hell out of a ryobi set.
Edit: then I use dowel with a cheap flush cut saw to plug the holes if need be. Works great.
TheWoodenOyster
1313 posts in 1840 days
#6 posted 09-10-2014 02:00 AM
All these guys are right. ^
I use the hell out of a ryobi set too. Just don’t go too fast. if you see smoke, you are going too fast. I burnt up a forstner bit yesterday when I forgot to turn down my drill press speed.
Loren’s video is a good way to do it too.
-- The Wood Is Your Oyster
View Vaul's profile
Vaul
#7 posted 09-10-2014 03:08 AM
Thank you all for the replies. I guess I always thought of forstner bits as being a drill press only bit, but it makes sense.
Do you use brad point bits very often? I’m thinking I might need to invest in a set of those as well.
Jon/Vaul
-- Jon (aka. Vaul)
17547 posts in 1762 days
#8 posted 09-10-2014 03:13 AM
I’ve tried brad point bits and Forstner bits for shelf pin hols and hands down the Forstner bit made cleaner holes in plywood. I use Forstner bits for screw holes too. I find it better if I locate the center and then go to full speed on the drill instead of going slow and then fast it works better.
TheFridge
#9 posted 09-10-2014 03:35 AM
Not much luck with brad point. I use regular bits with a backer to prevent blowout.
View tyvekboy's profile
tyvekboy
1719 posts in 2918 days
#10 posted 02-18-2016 08:56 PM
Jon – I use brad point drill bits a lot. I also use forester bits. These are the sets that I’ve got at Rockler.
22-piece-forstner-bit-set
Brad point drill set
Go with the big sets. Eventually you’ll need all of them.
Also for plugging holes, another good tool to get are plug cutters. I have all three in my tool collection.
Of course I realize you don’t have a drill press yet but that’s a reason why you need to add that tool to your aresnal. I would recommend a floor model drill press.
As far as plugging holes for tool mounts, I personally wouldn’t do it. Shops are alway evolving and tool mounts will be moved. The tool holders in my tool cabinet have been moved many times.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
View clin's profile
clin
797 posts in 901 days
#11 posted 02-19-2016 12:05 AM
Using the drill bits you have, you might try clamping some scrap wood down and drill through that.
A little trickier getting the hole exactly where you want, but maybe you can make it work.
-- Clin
View Jim Finn's profile
Jim Finn
2622 posts in 2827 days
#12 posted 02-19-2016 02:45 PM
I use a counter bore bit. IT makes the central hole for the screw and cuts a counter bore cleanly like a Forsner bit does. Works easily and quickly in a hand held drill or a drill press.
http://www.ebay.com/itm/Snappy-Tools-33208-1-8-X-1-2-SD-3-Flat-Bottom-Counterbore-1-4-Hex-Made-in-USA-/171708330334?hash=item27fa9d315e:g:1h0AAOSwv0tU-SU9
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2275 days
#13 posted 02-19-2016 04:38 PM
I’ve been using these DeWalt countersink/counterbore tapered drill bits for maybe two years now, and love them. They’re sharp, and once you set the depth, drill, countersink, and counterbore. The tapered bit is nice, and I find the sharp tapered point on the end makes it much easier to locate the hole than with a regular twist drill bit.
http://www.homedepot.com/p/DEWALT-Steel-Countersink-Set-3-Piece-DW2535/100531905
http://www.amazon.com/DEWALT-DW2535-Piece-Countersink-Assortment/dp/B0000225OU
View MrRon's profile
MrRon
4630 posts in 3148 days
#14 posted 02-19-2016 06:39 PM
Brad point bits. You need speed to produce a clean hole. A cordless drill isn’t fast enough. When I drill holes, especially in soft woods, I use a drill press running at top speed (5000 rpm). I get clean holes.
View JAAune's profile
JAAune
1780 posts in 2222 days
#15 posted 02-19-2016 07:06 PM
If you’re just doing a few holes and want a perfect fit, use a sharpened screw to do a clean counterbore.
